Why Are the Eigenvalues of This Matrix A and A + φ²B?
  • Context: Graduate
  • Thread starter Thread starter Gianfelici
    Eigenvalue Eigenvector
The discussion revolves around the eigenvalues of a specific N x N matrix defined as M^{ab} = A\delta^{ab} + B \phi^a \phi^b, where δ^{ab} is the identity matrix and φ is a column vector. Participants explore the multiplicities of the eigenvalues as stated in a paper and seek clarification on the calculations involved.
  • Technical explanation, Debate/contested
  • One participant presents the eigenvalues as A with multiplicity 1 and A + φ²B with multiplicity N-1, as stated in the paper.
  • Another participant challenges this by suggesting that the eigenvalues should be A with multiplicity N-1 and A + φ²B with multiplicity 1, proposing to first find the eigenvalues of the rank 1 matrix Bφ^aφ^b.
  • A later reply confirms the correction, agreeing that A has multiplicity N-1 and A + φ²B has multiplicity 1, indicating that the suggested approach was helpful in resolving the issue.
There is initial disagreement regarding the multiplicities of the eigenvalues, but a later response aligns with the corrected view that A has multiplicity N-1 and A + φ²B has multiplicity 1.
The discussion includes assumptions about the properties of the matrices involved and the implications of adding a rank 1 matrix to a scaled identity matrix, which may not be fully resolved in the exchanges.
Gianfelici
Hi, I have a problem with the calculation of the eigenvalue of a matrix. That matrix is an N x N matrix which can be written as:
##M^{ab} = A\delta^{ab} + B \phi^a \phi^b##
where ##\delta^{ab}## is the identity matrix and the ##\phi## is a column vector. The paper I'm studying says that the eigenvalue of this matrix are:
A with molteplicity 1
##A + \phi^2 B## with molteplicity N-1
but I can't understand why! Can anyone help me?
You should put ## around the latex code to render it :smile:
Thank you, now it'right
I think it should be
##A + \phi^2 B## with multiplicity 1.
First find the eigenvalues of the rank 1 matrix ##B\phi^a\phi^b##.
Then think about what happens when you add ##A\delta^{ab}##, which is A times the identity matrix.
yes, you're right, it was A with multeplicity N-1 and the other with multeplicity 1. I tried to use your suggestion and I solved it! thank you very much!
  • · Replies 33 ·
9K
