Why can this formula be applied for diffraction gratings?
The formula n(lambda) = d sin(theta) for determining maxima and minima in wave interference applies to diffraction gratings because they can be conceptualized as multiple pairs of slits. Each pair of slits contributes to the overall interference pattern, producing distinct maxima and minima. The integer n indicates the order of the maxima, while lambda represents the wavelength of the light. The spacing d is effectively the distance between adjacent slits in the grating. This understanding clarifies how the formula remains valid despite the increased number of slits in a diffraction grating.
Dragynfyre
So for 2 point sources (or 2 slits) the formula for finding the lines of maxima and minima for waves is n(lambda)=dsin(theta) and when n is an integer you would expect to find a maxima. However, I don't understand why this formula also applies to diffraction gratings since there are way more than 2 slits. So can anyone explain this to me?
Consider the grating as pairs of slits. All pairs produce maxima or minima.
ehild
