tahayassen
- 269
- 1
It seems that after a day, I can't edit my older posts. I've recently misled people in an older post of mine and I can't edit to correct it.
phinds said:That's just the way it is here (on purpose). Actually, I thought it was 8 hours, not 24.
tahayassen said:why not just use moderated edits?
Evo said:The point is that there have been many instances of people intentionally changing or deleting posts which makes a thread useless after many people already responded. This is why people should quote all or part of the post they are responding to, so if the OP goes back and changes their post, the responder won't appear to be the one making the mistake. There are many reasons that there is a time limit. We've had instances of members getting angry and going back and deleting all of their posts in numerous threads, making the threads meaningless.
If you realize a mistake after 24 hours, it's easy to just post a correction in the thread.
jtbell said:It could be that the forum software doesn't have this feature. Maybe one of the Admins can comment on this.
We don't have enough mentors to deal with minor edits. There would have to be a significant reason to have a mentor edit the original post when a new post containing the correction can easily be made within the same thread. We will do it as an exception.tahayassen said:If the admins can't setup moderated edits and it does turn out to be a limitation of the software, then maybe after 8 hours, the edit button can redirect to the report button.
The board software has an edit history (well, you can activate it), but it is a lot of work to check many posts - or even revert 100+ edits.tahayassen said:Doesn't vBulletin have post history? Aren't there rollbacks? Surely there is a more elegant method?
That would be a reason to report your post, I think. No one likes wrong posts.The unfortunate problem I have with creating a new post to correct an older post is when you make a mistake on the 3rd page, learn a couple of days later that you're wrong, and your correction is now on the 6th page.
I suggest creating a new post with your correction and then requesting (via the report button) that a short note pointing to the corrected post be added to the original.tahayassen said:The unfortunate problem I have with creating a new post to correct an older post is when you make a mistake on the 3rd page, learn a couple of days later that you're wrong, and your correction is now on the 6th page.
I have to agree. This is not one of those "exceptions" where a correction to the original post would be important or helpful. Much better to post the correction as a new post.Doc Al said:I suggest creating a new post with your correction and then requesting (via the report button) that a short note pointing to the corrected post be added to the original.
Editing a post three pages back isn't a great idea, especially if it's been responded to. They won't see the correction.
In rare cases, like this, where you couldn't spot the error until the edit window closed and it's not easily corrected by a subsequent post to clarify, just hit the report button and tell us what needs to be corrected. We don't mind doing this ocassionally for unusual circumstances.Fredrik said:One thing you can do is to report your own post (use the "report" button), and ask a moderator to change it for you.
I agree with mathwonk, as I also often need sleeping time to realize my mistakes.mathwonk said:I made a mathematical mistake last night in a post and was unable to edit it around 10 am this morning, so I presume the time is less than 24 hours, which I personally find inadequate. I usually realize my mistakes after sleeping on them.
to me, just allowing at least 24 hours to edit would also go a long way to solving the problem.
Apparently it's not possible to have differing edit windows.strangerep said:I agree with mathwonk, as I also often need sleeping time to realize my mistakes.
Is it possible to keep the current (short) edit timeout on the 1st post in a thread, but a longer timeout (24 hrs) on all subsequent posts?
That would address the homework cheating issue, and also partially eliminate potential work for mods if a member wants to modify their own post the next morning and must "report" it to a mod, requesting changes.
By "not possible", I guess you mean "not implemented" by vBulletin? Unfortunate, since the actual software mod would be dead easy. (sigh)Evo said:Apparently it's not possible to have differing edit windows.
I don't know the answer. I know we've tried several different remedies and we're looking at options in future upgrades we will need to make. If we could stop only edits of the OP, that would be enough, IMO, but I'm under the impression that is not an option. It does concern us because the last thing we want to do is make things difficult for our members that have a real need.strangerep said:By "not possible", I guess you mean "not implemented" by vBulletin? Unfortunate, since the actual software mod would be dead easy. (sigh)
As far as I know, the posts do not have a flag "is starting post of a thread" in the database, you would have to check the posting time (!) of all posts with the same threadid. And any hack in the vBulletin-mechanics can lead to problems at updates of the board software.strangerep said:Unfortunate, since the actual software mod would be dead easy. (sigh)
