Why coin drop down into the glass?
  • Thread starter Thread starter Aladin
    Drop Glass
The discussion centers on the physics behind a coin dropping into a glass when a boardcard is quickly pulled away. The key concept is inertia, which explains that the coin's inertia is greater than the frictional force between the coin and the boardcard. When the boardcard is removed rapidly, the coin does not have enough force to stay with it, causing it to drop straight down. If the boardcard is moved slowly, static friction allows the coin to move along with it. Understanding these principles clarifies why the coin falls when the boardcard is abruptly pulled.
Aladin
When we put a coin on a boardcard and both the boardcard and coin put on a glass.
when we hit the boardcard,why the coin drop down into the glass.??
what?? I don't understand...
Are you asking about the inertia of the coin or the surface tension of the water?\
inertia...it seems to say nothing bout water at all.
Well the short answer is that the force of friction between the coin and the board is not great enough to overcome the inertia of the coin
I suppose he knew that though...?
Apparently not, or he wouldn't have asked. We have no idea how old this lad is, or what his level of education is.
The inertial of the coin is very high, and as suodei said, overpowers the forces that hold it to the board. When the board is abruptly removed, the coin stays behind. It's the same principle as the old trick of pulling a tablecloth off while leaving the dishes behind. With a slower movement, the coin would stay with the card.
As several have noted, the answer relates to the inertia of the coin. All objects that have mass require a force to get them moving (or change their state of motion). The only horizontal force on the coin is the friction between card and coin. If there were no friction, then you could slide the card away at any speed and the coin wouldn't move (until it started falling, of course).
But there is friction. If you move the card slowly, then static friction will move the coin along with the card. But if you move the card quickly, the much lower kinetic friction will be acting: the coin will move, but not as quickly as the card. Now if you move the card real quick, that friction force won't have much time to accelerate the coin; it appears to fall straight down (actually it must move a little to the side as well).
Of course there is no answer if the question is not understood. :frown:
Thank you Doc Al my problem is solved by your answer.
