Why current leads to a greater resistance
  • Thread starter Thread starter nokia8650
    Current Resistance
Current increases the resistance of a metal wire because flowing electrons collide with the wire's atoms, causing them to vibrate more and raise the temperature. This heightened atomic vibration leads to more frequent collisions between electrons and atoms, resulting in increased resistance. In contrast, in semiconductors like silicon, higher temperatures promote more electrons to the conduction band, which increases the number of charge carriers and decreases resistance. The explanations provided align with established principles of electrical conductivity. Overall, the discussion highlights the contrasting behaviors of metals and semiconductors in response to current and temperature changes.
nokia8650
Why does current cause an increase in the resistance of a metal wire? Is the below explanation sound?:
As current flows, electrons collide into the atoms of the wire. This causes them to vibrate with a greater amplitude, increasing the temperature. The increased vibration of the atoms results in electrons colliding with the atoms more frequently, increasing the resistance.
Conversely, in a semi-conductor (eg. silicon), the increased temperature causes electrons to be promoted to the conduction band, increasing the number of electrons available for conduction, decreasing resistance since there are more charge carriers per unit volume.
Thanks
Sounds about right to me :approve:
