Why did my D cell battery get hot for no apparent reason?
  • Thread starter Thread starter mcf455
    Battery Cell Hot
A D cell battery can become hot due to a fault current, even when not connected to a circuit. In one case, a user experienced overheating after disconnecting the battery from an MP3 player, leading to concerns about potential short circuits. Testing revealed that the leads may have inadvertently touched, causing the initial heating. Another user reported a similar incident with a flashlight, attributing the heat to an internal short within the battery. These experiences highlight the importance of ensuring proper handling and storage of batteries to prevent overheating.
mcf455
"D" cell battery gets hot
As a hobbyist, I was playing around with an MP3 player that uses a single alkaline AAA battery. I wanted to see if the player would still work if I attached a "D" cell battery to the device. I went to Radio Shack and puchased a "D" cell battery holder which has two leads.
I added connectors on the end of each lead and plugged them into the player. The player worked properly.
I then disconnected the leads from the player and left the "D" cell battery in the holder sitting on the table. It sat for about an hour and when I went to remove the battery, it was HOT to the touch. The two leads were not connected to anything or laying against anything.
I am truly puzzled as to why the battery got hot. I thought if nothing was attached to the
leads, it was not completing a circuit. So why did the battery get hot?
I figured this is a great site to pose this question.
Thanks in Advance
Thanks in Advance
Welcome to the PF.
There is no reason for the battery to get hot unless there was some fault current flowing, or if it was sitting in the direct sunlight or something. You are right to be concerned. Could there have been some other circumstance that caused the battery to feel warm/hot?
berkeman, thanks for the quick response. I had the unit sitting on my kitchen table so it was not in direct sunlight. Retracing my steps, I did play the mp3 player with the D Cell battery for 30-45 minutes, I unplugged battery from the MP3 player but did not notice it being hot at that time. I left the "D" cell (still in the holder) sit for about an hour. When I went to move it that's when I noticed it was hot. The leads were not connected.
I think I have a defective battery. I will run through this test scenario again. I will reuse the same battery and see if I get the same results. Then I will retest it with a different "D" cell and see what results I get.
I will post the results of my test.
Thanks Again
What type of "D" cell was it? Was it Zinc Carbon, Alkaline or a rechargeable?
Did you test the voltage of the battery afterwards. Was it "flat"?
The most common reason why that would happen is that the battery got short circuited. The two wires don't need to touch each other, they just need to contact some common conducting object, eg piece of metal cutlery for example.
Yes it could be just a random failed battery but the chances against it are about a billion to one. I'm guessing that the chance that you inadvertently shorted it are considerably higher than that.
berkeman/uart thanks for your responses
I ran through the scenario as described in my previous posts twice, once with the original D cell battery (that got hot)
and also with a brand new "D"cell. Both are alkaline batteries, the one that got hot measured 1.4 volts and the brand
new one measured 1.5 volts.
This time when I disconnected the leads from the MP3 player, I taped up the postive lead to be sure there was no
chance of a short circuit.
In either case, I could not reproduce the result of the battery getting hot. I have to surmise that the leads must have
been touching and this is what originally caused the battery to heat up. I have noticed the leads from the battery holder
do curl toward each other.
Based on my IT background, you can chalk this up to a user error.
Thanks so much for your input.
Its the battery sometimes
Hi,
I had it happen last week (24 July 2013) to a Duracell D cell in a flashlight. One battery dated 2005 that was still good had gotten hot inside the flashlight. I had trouble with the switch and left it on the kitchen table. An hour later I touched it and wow. Took it apart to find one battery (D size) hotter than can be touched. I threw it out the window on the grass. The other battery was cold. The plastic flashlight was very hot. An hour later I measured the volts on the now cold battery and it was down to 1.0 volts...dead. The other battery was still 1.4 volts and dated 2012. So it can happen. Its an internal short inside the cell. Dont have any idea why it started doing this. I did not bang the battery or high quality flashlight. I thought I would post this because I had it happen 5 or 8 years ago and I thought I was loosing my mind. It really did happen last week the way it happened before.
Steve Stillman
Shrewsbury, MA
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
