Why Do DC Brushless Motors Need Hall/EMF Sensors?
DC brushless motors require sensors like Hall or EMF sensors to provide feedback on the rotor's position, ensuring proper synchronization with the stator's magnetic field. Without these sensors, the controller could misalign the rotor and stator, causing vibrations instead of smooth rotation. While it is theoretically possible to control a synchronous motor without sensors by estimating rotor position through voltage-current relationships, this method still relies on some form of rotor position control. The need for accurate feedback is crucial for effective commutation and overall motor performance. Therefore, sensors play a vital role in maintaining the efficiency and functionality of DC brushless motors.
VarietyBook
I understand the basic gist of the whole DC brushless motor, but I don't understand why there needs to be a sensor. Why can't the controller just alternate between phases at a constant rate? What I mean is that if there are a fixed number of ways the coils can be charged, why not just alternate between them and keep going? I hope my question makes sense.
"There has to be a sensor giving feedback to the system indicating when the rotor has reached the desired position. If commutation is done faster than this, the rotor magnets go out of sync with the stator magnetic field and the rotor vibrates instead of rotating. There needs to be a sensing method to determine if the position of the rotor is in sync with the stator, so that the next commutation can be made. There are many types of sensors used in motors: encoders, potentiometers, switches, and others."
From http://www.freescale.com/files/microcontrollers/doc/app_note/AN4058.pdf
Your assumption is that the rotational rates are uniform, and that everything is perfect ... we use feedback-control systems because that ain't so!
It is possible to control a synchronous permanent magnet motor without the use of a sensor*. Instead the position of the rotor is estimated through the V-I relationship (or "back emf"). But there is still some control that somehow involves the rotor position.
*as in, this scheme does not require an additional doodad in the motor itself
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
