Why do ferrofluids move towards regions with higher magnetic field gradients?
  • Context: Graduate
  • Thread starter Thread starter styleworker
    Convection
The discussion centers on the behavior of ferrofluids in response to magnetic field gradients. It establishes that ferrofluids, which are superparamagnetic, move towards regions of higher magnetic field when subjected to an external magnetic field gradient. The relationship between magnetization and magnetic field gradients is mathematically expressed through the equation divB=0, where B is the magnetic field, M is the magnetization, and H is the magnetic field strength. The participant seeks a deeper physical explanation for this phenomenon, particularly under constant external magnetic fields.
  • Understanding of superparamagnetism in ferrofluids
  • Familiarity with magnetic field gradients and their effects
  • Knowledge of vector calculus, particularly divergence
  • Basic principles of thermomagnetism
  • Research the principles of superparamagnetism in ferrofluids
  • Study the effects of magnetic field gradients on fluid dynamics
  • Explore thermomagnetic effects in materials science
  • Examine mathematical modeling of magnetic fields in ferrofluids
Researchers in materials science, physicists studying magnetic phenomena, and engineers working with ferrofluids in applications such as drug delivery and magnetic cooling systems.
styleworker
Hello!
I'm currently reading papers about ferrofluids and trying to understand the physics behind this topic.
I do understand, that if we consider a vertikal temperature gradient, we get a antiparallel magnetization gradient. The ferrofluid with a the higher magnetization will move to the area with higher magnetic field, if we have applied an external magnetic field gradient.
But if we consider a constant external magnetic field, the magnetization gradient induces a antiparallel magnetic field gradient. As far as I know, ferrofluids are superparamagnetic and therefore density of magnetic field lines will rise. So, in my mind, the magnetic field gradient has to be in the same direction as the magnetization gradient for a constant external magnetic field.
Here you can see an illustration of the above example: http://www.mpipks-dresden.mpg.de/~adlange/research.html#thermomagnetic"
Can somebody explain this phenomena?
The mathematical solution is actually easy:
[itex]div\vec{B}=0[/itex]
with
[itex]\vec{B}= \mu_0(\vec{M}+\vec{H})[/itex]
[itex]\vec{H}=\begin{pmatrix} 0 \\ 0 \\ H_z \end{pmatrix} ,\vec{M}=\begin{pmatrix} 0 \\ 0 \\ M_z \end{pmatrix}[/itex]
we get
[itex]\frac{dH}{dz} = -\frac{dM}{dz}[/itex]
But the physical explanation?!
  • · Replies 23 ·
10K
