Why Do Hess's Law Calculations Show Discrepancies in Enthalpy Values?
  • Thread starter Thread starter mrxtothaz
    Law Reaction
This discussion focuses on the discrepancies in enthalpy values calculated using Hess's Law for three chemical reactions involving sodium hydroxide (NaOH). The enthalpy changes for the reactions are as follows: Reaction 1: ∆H°r: -5.80 kJ, Reaction 2: ∆H°r: -5.06 kJ, and Reaction 3: ∆H°r: -16.7 kJ. The combined enthalpy of Reactions 1 and 2 yields -10.9 kJ, which does not match the expected value of Reaction 3. The participants explore potential sources of error, including the assumption of specific heat capacity and density of solutions compared to water.
  • Understanding of Hess's Law and its application in thermochemistry.
  • Knowledge of enthalpy changes in chemical reactions.
  • Familiarity with net ionic equations and their significance.
  • Basic principles of calorimetry and heat capacity.
  • Investigate the principles of Hess's Law in detail.
  • Learn about the calculation of enthalpy changes for reactions involving spectator ions.
  • Research the effects of specific heat capacity and density on calorimetric measurements.
  • Explore common sources of error in laboratory thermochemistry experiments.
Chemistry students, educators, and laboratory technicians interested in thermodynamics, particularly those studying enthalpy changes and Hess's Law applications.
mrxtothaz
I have been provided with the results of a lab:
Reaction 1:
NaOH(s) --> Na+(aq) + OH-(aq)
Reaction 2:
Na+(aq) + OH-(aq) + H+(aq) + Cl-(aq) --> H2O(l) + Na+(aq) + Cl-(aq)
OH-(aq) + H+(aq) --> H2O(l)
Reaction 3:
NaOH(s) + H+(aq) + Cl-(aq) --> H2O(l) + Na+(aq) + Cl-(aq)
NaOH(s) + H+(aq) --> H2O(l) + Na+(aq)
The enthalpies for each reaction:
∆H°r: -5.80 kJ (Reaction 1)
∆H°r: -5.06 kJ (Reaction 2)
∆H°r: -16.7 kJ (Reaction 3)
I have been asked to add the equations of 1 and 2 (Hess's Law), and to compare the sum with equation 3.
Hess's Law.
NaOH(s) --> Na+(aq) + OH-(aq) ∆H°r: -5.80 kJ (Reaction 1)
OH-(aq) + H+(aq) --> H2O(l) ∆H°r: -5.06 kJ (Reaction 2)
NaOH(s) + H+(aq) + OH-(aq) --> Na+(aq) + H2O(l) + OH-(aq) ∆H°r: -10.9 kJ (Reaction 1+2 intermediate)
NaOH(s) + H+(aq) --> Na+(aq) + H2O(l) ∆H°r: -10.9 kJ (Reaction 1+2)
NaOH(s) + H+(aq) --> Na+(aq) + H2O(l) ∆H°r: -16.7 kJ (Reaction 3)
So, as can be seen, the equations for reactions 1&2 are added and are identical to that of reaction 3. However, the enthalpies of reaction are way different. I do not know how I can account for this steep a difference, as all the lab results were provided with the question. The only difference is that, in the addition of reactions 1&2, there was a hydroxide ion on both sides of the equation that was canceled out (since I was asked for the net ionic equations for each reaction). Could this account for the difference, or does it have no role in the enthalpy of reaction, given that it is a spectator ion?
If I did nothing wrong, I suspect I am supposed to identify this discrepancy between reaction 1+2 with reaction 3.
I'm looking into possible sources of error; the only thing I can think of is that the experimenters assumed the specific heat capacity of each solution to be same as that of water? As with density.
Could this account for the discrepancy?
Reaction 1:
Reaction 2:
Reaction 3:
Hess's Law.
How did you get H+aq? From HAaq?
Not sure what you mean by HAaq, but the hydrogen ions arise from the dissolution of hydrochloric acid.
Then shouldn't there be an enthalpy of HClaq -----> H+aq + Cl-aq?
I'm sure a solution can be found by those means, but the three reactions should be enough for this kind of exercise.
The first two equations combined yield the third equation, so there is no need for additional equations. The only issue is that the enthalpies are quite a bit off.
Do you believe that this difference can be accounted for by the fact that density & heat capacity of water was assumed for each solution? Or is there an error in any of my work?
Note that no experimental error can be attributed to my doing, since the data itself was provided with the question.
  • · Replies 50 ·
