Why do the smallest luminous objects lie along a line corresponding to
  • Thread starter Thread starter Brown Arrow
    Line
The discussion centers on why the smallest luminous objects, specifically white dwarfs, align along a line on the Hertzsprung-Russell (HR) diagram corresponding to a radius of about 1 Earth radius. This phenomenon is attributed to electron degeneracy pressure, which stabilizes white dwarfs at a specific size, preventing them from collapsing further or exploding if they exceed this mass limit. Participants clarify that while white dwarfs are supported by this pressure, Earth-sized objects like Earth itself are not. The conversation also touches on the relationship between a star's mass and its size, noting that only stars within certain mass ranges can become white dwarfs. Ultimately, the alignment on the HR diagram reflects the equilibrium of forces acting on these stars.
Brown Arrow
why do the smallest luminous objects lie along a line on the HR diagram corresponding to radius of 1 Earth radius?
I'm kinda lost on this question its from past exam..
I think it has to do with degeneracy pressure but that does not sound right to me...
could someone help me out?
Astronomy news on Phys.org
They don't - so I suspect there is a missing context here.
What does the question refer to when it talks about "lie along a line"?
sorry, its the Hertzsprung-Russell Diagram(HR-diagram) they are referring to
H-R diagram plots luminosity against temperature.
http://abyss.uoregon.edu/~js/ast122/lectures/lec11.html
... 1 Earth radius would be about 0.009 Solar Radii ... which cuts right through the middle of the White Dwarfs.
So the question amounts to: "why are white dwarf stars roughly the same size?"
its because of electron degeneracy pressure if they surpass this radius means increase in mass and White Dwarf would explode.
so this means that most Earth size objects are supported by electron degeneracy pressure correct?
P.s thanks for the reply :)
No - for example: the Earth is an Earth-sized object not supported by electron degeneracy.
I usually picture white dwarfs as really big atoms - they don't decay because their gravity holds all the bits in.
You get three lots of pauli pressure - in the electrons, the protons and the neutrons. They are all similar order-of-magnitude sizes for much the same reason atoms are - thought the forces are a bit different - add more mass and the gravitational attraction gets stronger faster than any repulsion.
On the HR diagram, the really dim WDs are somewhat smaller than the Earth.
You need to think what makes for a dim White Dwarf compared with a bright one... but it's just where the equilibrium ends up.
Stars more massive or less massive than certain amounts just don't end up as white dwarf stars.
The amount of mass it has determines its size.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
Today at about 4:30 am I saw the conjunction of Venus and Jupiter, where they were about the width of the full moon, or one half degree apart. Did anyone else see it? Edit: The moon is 2,200 miles in diameter and at a distance of 240,000 miles. Thereby it subtends an angle in radians of 2,200/240,000=.01 (approximately). With pi radians being 180 degrees, one radian is 57.3 degrees, so that .01 radians is about .50 degrees (angle subtended by the moon). (.57 to be more exact, but with...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
