Why do we add turbulence to the rotating water in our experiment?
The discussion centers around the role of turbulence in a rotating water experiment, particularly in relation to the behavior of dye in the water. Participants explore the differences between turbulence and diffusion, the effects of rotation on fluid dynamics, and the implications for understanding oceanic and atmospheric phenomena.
  • Experimental/applied
  • Some participants express confusion about the distinction between turbulence and diffusion, questioning why turbulence is emphasized in the experiment.
  • It is suggested that the behavior of dye in a rotating bucket differs from that in still water, with diffusion being the primary mechanism in still water.
  • One participant mentions the Atwood number as a factor that may influence whether turbulence or diffusion dominates in the experiment.
  • Another participant introduces the concept of Rayleigh-Bénard instability, relating it to the formation of vertical columns in the dye's behavior under certain conditions.
  • There is a discussion about whether turbulence can be "added" to the system, with some asserting that turbulence is a naturally occurring phenomenon that arises under specific conditions.
  • A later reply clarifies that stirring the water introduces turbulence, which affects the dye's movement and creates observable patterns.
Participants do not reach a consensus on the necessity of "adding" turbulence, with some asserting it occurs naturally while others discuss its introduction through stirring. The relationship between turbulence and diffusion remains a point of contention, as does the interpretation of the experimental results.
The discussion highlights the complexity of fluid dynamics, particularly in the context of rotating systems, and the varying interpretations of experimental observations. Limitations in understanding the underlying principles of turbulence and diffusion are evident among participants.
This discussion may be of interest to students and educators in physics and earth sciences, particularly those exploring fluid dynamics, turbulence, and their applications in natural systems.
Kolika28
<Mentor moved to Physics>
My teacher talks about turbulence (2D and 3D), but I don't quite understand this. How is the turbulence different in the two buckets, and why does my teacher talk about turbulence but not diffusion? Is not diffusion the reason why the dye spreads in the water? I have searched a lot on the internet, but I don't find any information that explains this in detail. The reason that I'm asking about this in the "earth science" forum, is because it's supposed to be related to the oceans and atmosphere. Again, I'm struggling to see the relation between the ocean and this experiment. I would really appreciate some help, because I'm lost.
Moving to Classical Physics - you will get good answers there
I am having trouble visualizing what you mean in the rotating bucket case. Do you have a YouTube video or anything that illustrates what you mean?
Whether "turbulence" or diffusion dominates is likely going to depend on the Atwood number (a dimensionless density ratio) between the dye and the water.
Kolika28 said:
Summary:: Hey! I don't know if this is the right forum to ask this type of question, but I guess "earth sciences" is the closest topic here. So why does a drop of dye in a rotating bucket form vertical columns, but in non-rotating water, it flows out in all directions?
The difference between an ocean and bucket is one of scale. Diffusion (due to concentration gradients) is always occurring in a fluid (gas or liquid) as well as advection (bulk motion), but the effect of advection is dependent on velocity and gradients of energy or momentum. See - https://en.wikipedia.org/wiki/Advection - for a discussion.
In a calm sea with essentially no gradient of density, temperature (thermal energy), diffusion would dominate. With a driving force, such as from wind or waves, or strong gradients, then convection (and turbulence) becomes more important, and at some point, dominant.
In still water in a bucket, the spreading of dye is driven by diffusion, and possibly some convection. W
Thank you for a great answer! :smile:
It's called DIYnamics. Here is a link to a youtube video
I assume (base don this video) that by "vertical columns" you are referring to the cellular structure they describe in the video?
This is called the Rayleigh-Bénard instability or Rayleigh-Bénard convection. This most commonly occurs with a fluid heated from below but it can also occur with a fluid cooled at the top (as was made clear in the video when it references fluid cooled by evaporation at the surface). You end up with a layer of cooler, denser fluid sitting on top of a layer of warmer, less dense fluid, which is an unstable system. If the "bucket" isn't spinning, then it doesn't set up the same degree of cooling due to the relative motion of the water and air that you get from the rotating bucket case.
Here it is demonstrated on a stove top:
And here it is demonstrated in a lab setup with a rotating column:
Ohh, thank you! Really appreciate your help!
I forgot to ask last time, but why do we add turbulence? Is it a weather phenomenon we are trying to demonstrate?
What do you mean "add turbulence?" Turbulence is a naturally-occurring phenomenon. It happens on its own as long as conditions are met for its development. We don't need to add anything.
Ups, I'm sorry for the confusion. I forgot to mention something. In the experiment we also studied what would happen if we stirred (added turbulence) to the rotating water before adding dye. We then saw these vertical curtain wrapping around each other, still some sort of 2D motion. From the top of the bucket it looked like swirls. And then comes the question I asked at last:
  • · Replies 74 ·
  • · Replies 18 ·
