fxdung
- 387
- 23
Why do we know the velocity of all photons are the same as the velocity of light?Can we deduce this or we must have experiment test?What is the experiment test?
Photons are light. They have the speed of their speed. Is that what you really meant to ask?fxdung said:Why do we know the velocity of all photons are the same as the velocity of light?Can we deduce this or we must have experiment test?What is the experiment test?
More effects are described in the following article.(Lecture 2, 2.2 Difficulties of Speculative Theories):
He asked, "Tell me, Professor Feynman, how sure are you that the photon has no rest mass?"
...[snip]...
My answer was that, if we agreed that the mass of the photon was related to the frequency as \omega=\sqrt{k^2+m^2}
photons of different wavelengths would travel with different velocities. Then in observing an eclipsing double star, which was sufficiently far away, we would observe the eclipse in blue light and red light at different times. Since nothing like this is observed, we can put an upper limit on the mass, which, if you do the numbers, turns out to be of the order of 10^{-9} electron masses.
See alsoCh 3 Implications of a photon mass 83
3.1. The dispersion of light 83
3.2. The Yukawa potential in static fields 84
3.3. The longitudinal photon 84
3.4. Special relativity with nonzero photon mass 85
3.5. AB and AC effects with finite photon mass 85
3.6. Monopoles and the photon mass 87
3.7. The Casimir effect for massive photons 88
3.8. Photon mass and blackbody radiation 89
3.9. Other implications
So again: photons are light [and are em waves]. They have the speed of their speed.fxdung said:I am starting read Special Relativity,then I like to know why photon has same speed as of EM wave speed of light, without relying on Special Relativity theory.
I am not sure that this makes any sense. A photon is a concept of QED so it doesn’t make sense to ask about a photon outside of that context. QED has relativity built into it. So I don’t think there is a way to ask about a photon without relying on relativity.fxdung said:I am starting read Special Relativity,then I like to know why photon has same speed as of EM wave speed of light, without relying on Special Relativity theory.
Yes, everything follows from that. You can also derive it from the basic symmetry principles like homogeneity, isotropy, etc.fxdung said:Does it only depend on invariant of spacetime interval?
fxdung said:Photon(particle) has statistical manifestation
fxdung said:in what sense does photon have statistical manifestation?
Yes. You cannot say 'where it is' ever. Hence the fact that people say a photon has a presence at either of the two Young's Slits; it could be anywhere in space during the, (poorly described as) flight. There is no problem with the fact that it has to end up somewhere definite because it will experience no effect of time (SR) and so the initial worry about that information getting to all parts of the photon at the instant it's detected, is groundless.fxdung said:Then because speed of photon is definite, then the position of photon is very uncertainly?
snorkack said:We have a lot of experiments, which clearly show that photons do NOT all travel at the same speed.
Is that according to NMQFT (Newtonian-Maxwellian-Quantum Field Theory)?fxdung said:If we suppose position of photon is somewhere in EM wave packet, then how can we explain Vavilov experiment?But it is reasonable to suppose the position of photon is limited in wave packet of EM field.
EPR said:Photons travel at the same speed(that of light) only in vacuum.
Can you name just one that measures c in a vacuum and gets a spread of values? Dispersion and observed gravitational bending of light do not disprove that c is constant - you just need to describe the phenomena in the right terms.snorkack said:We have a lot of experiments, which clearly show that photons do NOT all travel at the same speed.
fxdung said:What do you mean when saying NMQFT?
Well-defined position of a particle (without measurement) is a concept from Newtonian physics.fxdung said:If we suppose position of photon is somewhere in EM wave packet, then how can we explain Vavilov experiment?But it is reasonable to suppose the position of photon is limited in wave packet of EM field.
It's unfortunate that you start to learn about quantum mechanics on the example of photons. The problem is that photons were the first discovery of the fact that classical physics needs to be substituted by quantum mechanics due to Planck's discovery of the theoretical foundation of the black-body radiation spectrum. Now many textbook writers think they have to talk about "photons" in the introductory sections of quantum-mechanics textbooks and also in the popular-science literature.fxdung said:Then because speed of photon is definite, then the position of photon is very uncertainly?
No, and that´ s my point. We know what it looks like when photons have different speeds, and it always appears related to the effects of medium on photon, not intrinsic properties of photon. Whereas rest mass of photon would show up as low frequency radio waves having index of refraction that diverges at low frequencies independent of medium.sophiecentaur said:Can you name just one that measures c in a vacuum and gets a spread of values?
Do we know? Are you sure? Because I have no idea.snorkack said:We know what it looks like when photons have different speeds
That doesn't make any sense to me. How would that suggest a rest mass of photons?snorkack said:Whereas rest mass of photon would show up as low frequency radio waves having index of refraction that diverges at low frequencies independent of medium.
Diffraction of light is due to photons of different frequency having different speed. But it always looks due to interaction with medium.lomidrevo said:Do we know? Are you sure? Because I have no idea.
Because of the relationlomidrevo said:That doesn't make any sense to me. How would that suggest a rest mass of photons?
No, it isn't. @Lord Jestocost alredy mentioned in above post that "different speed" is only apparent. I also suggest to read the Feynman's lecture linked by him, it explains why.snorkack said:Diffraction of light is due to photons of different frequency having different speed.
I am not sure what you are trying to do here. I hope you know that "speed of light is the same constant for all observers" is a postulate of special relativity. You just cannot use the results of SR (like ## E^2 = p^2c^2 + m^2c^4 ## ) to try to "simulate" how it would be if constancy of speed of light is violated. The theory is build on this fact. The equations would not be valid if ##c## could vary. According to SR, for light you get exactly ##E = pc##, point.snorkack said:Because of the relation
E2=p2c2+m2c4
Assuming zero m, it simplifies as
E=pc
It approaches E=pc when E>>mc2
But it would change and the speed of particle would fall as E approaches mc2. And the speed would have no lower bound.
You could just as well call it a "postulate of special relativity" that speed of neutrinoes is the same constant for all observers. Except, oops, neutrinoes oscillate... which doesn´ t actually affect special relativity. Special relativity merely requires a special maximum speed to exist, and does not require any particles to actually travel at that speed - whether it is all neutrinoes, one of three neutrinoes, no neutrinoes but all photons or not photons either (but only gravitons) - SR is unaffected.lomidrevo said:I hope you know that "speed of light is the same constant for all observers" is a postulate of special relativity.
