timmeister37
- Messages
- 124
- Reaction score
- 25
- TL;DR
- Why cannot AC go back and forth on an AC circuit on the same line?
Preface to thread: The power source in both diagram 1 and diagram 2 is a wall outlet with alternating current power, not a battery. The load in both diagram 1 and diagram 2 is a light bulb, even though I forgot to label the load in diagram 2.
__________________________________________________________________________________________________
I know that on an alternating current circuit, you have to have both a line 1 and a line 2 to have a circuit. Here is a pictorial diagram of an alternating current circuit:
Diagram 1 is the diagram in the photograph posted above. Notice how in diagram 1 you have a line 1 in green, and there is a line 2 after the load in pink. I know that if the switch was closed in diagram 1, alternating current would flow in the circuit, and the light bulb would light up.
Why would an alternating current circuit like in Diagram 2 not work? Here is diagram 2:
If I closed the switch in diagram 2, why would alternating current not flow from the power source to the light bulb and then back to the power source? Since the direction of the alternating current switches back and forth sixty times per second with 60hz power, why couldn't the power flow from the power source to the light bulb for 1/60th of a second, light up the light bulb, and then flow back to the power source using the same wire in the next 1/60th of a second? I know that diagram 2 would not function as a circuit. I know that there would have to be a line two going from the load back to power for there to be a circuit. My question is: Why does one need a line 2 to make a circuit?
