Why Does a Black Object Reflect Light Despite Absorbing All Colours?
  • Thread starter Thread starter no idea
    Light
A black object appears black because it absorbs all colors of light, yet it still reflects some light due to its surface properties. The reflection occurs when the absorbed light alters the electronic configuration of the object's molecules, allowing some light to be reflected instead of absorbed. Additionally, the law of black bodies indicates that objects can reemit absorbed light energy, although this is often not visible. The color of an object is defined by the wavelengths it reflects; for instance, a red car reflects red light while absorbing others. Overall, even black objects reflect a small amount of light, preventing them from being completely invisible.
no idea
why the light reflected by a object is not the object's colour but it is sunlight?for example , a black object absorb all colour so we can see it is 'black' but why it still reflect some light when we watch it/
Science news on Phys.org
I'm not sure but here's what I think. There are two ways I can think of for the object to reflect some of the light: first, the light that is absorbed by object changes the electronic config. of the molecule's electrons and if at that same moment another wave of light hits the molecule rearranged, maybe that molecule won't have the same absorbant effect on light and may reflect it instead. Second, there is a the law of black bodies that say that depending on the temperature, an object reemits all or some of the light energie it receives, usually this light is not visible but it could be.
hope this satisfies you.. at least a little bit.
thx
thx very much
Also, if a black object were totally black, it would essentially be invisible. Every black object you've seen refelcts a little bit of light.
An object's color is determined (less technical than Mikado's good response) by what it absorbs and reflects. A red car is red because it absorbs everything except red. An object that reflects (but scatters) all colors is white - an object that reflects all colors at the angle of incidence is a mirror.
There is another effect, having to with Brewster angle, where light is totally reflected, irrespective of the surface material. I am not too well acquainted with it. Try google?
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
