Why does fluid flow faster in a narrow tube?
Fluid flow is faster in a narrow tube due to the principle of continuity, which states that the mass flow rate must be constant for incompressible fluids. As the fluid transitions from a larger diameter to a narrower one, its velocity increases to maintain the same volumetric flow rate. This increase in speed results in a decrease in pressure, as described by Bernoulli's equation (P + 1/2ρv² + ρgh = constant). In separate, unconnected tubes, the flow rate is not guaranteed to be faster in narrower tubes, as flow dynamics can vary based on other factors.
  • Understanding of fluid dynamics principles
  • Familiarity with Bernoulli's equation
  • Knowledge of mass flow rate and volumetric flow rate
  • Basic concepts of pressure and energy in fluids
  • Study Bernoulli's principle in detail
  • Explore the concept of fluid continuity in various scenarios
  • Investigate the effects of fluid viscosity on flow rates
  • Learn about applications of fluid dynamics in engineering
Engineers, physicists, and students studying fluid mechanics, as well as anyone interested in understanding the behavior of fluids in varying tube diameters.
threy
Fluid flows faster in a narrow tube which results in low pressure and high pressure in a large tube?
Some context would be helpful.
If you have a fluid going from a large pipe to a narrow pipe (or vice versa), the fluid has to flow quicker in the narrow pipe to get the same flow rate ([strike]volume[/strike] mass per time).
If you have a fluid going from a large pipe to a narrow pipe (or vice versa), the fluid has to flow quicker in the narrow pipe to get the same flow rate (volume per time).
This is correct. And I'll add that there is a distinction to be made between this (a single tube with variations in width), and multiple (different) tubes.
In the later scenario: If you have 2 separate tubes which are not connected, there is no guarantee that water will flow faster through a narrower tube.
More correctly, the mass flow rate must be maintained (continuity). Volumetric flow rate only works here for an incompressible fluid.
hi threy! :smile:
pressure is not only force per area, it is also energy per volume
(1 Pa = 1 J/m3)
therefore conservation of energy requires that if the kinetic energy increases (ie if the speed increases), then the pressure must decrease
(mathematically, this is Bernoulli's equation … P + 1/2ρv2 + ρgh = constant along any streamline)
Or put another way: the fluid speeds up when it enters a narrower portion of the tube. Since it speeds up, it has an acceleration, therefore a net force, in the direction it is moving. This net force must result from a higher pressure behind the fluid (in the larger tube portion) and a smaller pressure ahead of the fluid (in the smaller portion).
but why the fluid go faster in narrow tube than a thicker tube?
Perhaps it's this simple...
If the fluid is incompressible the flow rate (in cubic meters per second) must be the same at all points along the pipe. What goes in must come out.
If the cross sectional area (in square meters) changes the velocity (in meters per second) must change to maintain the same flow rate.
Right.
This thread is from 2013. If there is a new question, please open a new thread.
  • · Replies 48 ·
  • · Replies 25 ·
  • · Replies 35 ·
  • · Replies 160 ·
10K
