Why does induced current in loop vary twice with rotation of coil?
The induced current in a rotating square loop of wire varies twice with the frequency of rotation due to the magnetic flux changes experienced during each complete rotation. As the loop rotates in a magnetic field described by B=B_{0}sin(ωt), the magnetic flux through the loop fluctuates, resulting in two cycles of maximum and minimum flux per rotation. This leads to the current pulsing twice for each complete revolution of the coil. The induced current can be derived using Maxwell's equations alongside Ohm's law. Understanding this relationship is crucial for analyzing electromagnetic induction in rotating systems.
trelek2
A square loop of wire of side a is rotating with frequency \omega in a magnetic field. I understand that at time t, a magnetic field B=B_{0}sin\omega t passes through the loop. But why does the current induced in the loop vary twice with the frequency of rotation? What is the expression of the current induced?
The emf induced around the contour of the coil is proportional to the rate at which the magnetic flux through the coil varies in time. This variation undergoes two min/max/min cycles per rotation of the coil. Hence current in the coil pulses twice per revolution. The current induced can be calculated from Maxwell's equation for the curl of E, plus Ohm's law.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
