- 2,176
- 8
OK, well, here's a reason why a certain momentum/energy corresponds to a certain wavelength: perhaps you know that a light wave is made up of oscillating electric and magnetic fields. So when this wave hits (and is absorbed by) a (free-ish) charged particle, the electromagnetic field will cause the particle to move around. If the particle is confined to a straight line (like an antenna) parallel to the electric field, it will oscillate in a sine wave; if it's completely free, it may undergo some more complicated motion.brainstorm said:No, I wasn't reasoning about logical memory aids. I was trying to establish a logical reason why a certain amount of momentum/energy would result in a certain wavelength with constant velocity. It does seem logical that energy would be expressed as wave frequency if velocity was a given, but that still doesn't answer the question of why the velocity is given at the speed it is given.
Anyway, the higher the frequency of the radiation, the faster the EM field oscillates, and thus the faster the particle will move. If the particle moves faster, it has more energy; therefore energy is directly related to frequency. (This argument doesn't tell you that energy is proportional to frequency, just that when one gets bigger, so does the other)
Also, the higher the frequency of the radiation, the less time it takes for one complete cycle of the wave to pass through a given point. Assuming that the wave moves at a constant speed, if it takes less time for one cycle of the wave to pass through a point, the distance covered by one cycle of the wave (i.e. the wavelength) will be shorter. Thus higher frequency correlates to shorter wavelength; frequency is inversely related to wavelength. (This argument doesn't tell you that frequency is inversely proportional to wavelength, but if you know that velocity = distance / time it's pretty straightforward to figure out)
Combining the conclusions from the previous two paragraphs:
high energy = high frequency = short wavelength
What, like E=mc2?brainstorm said:This is too arbitrary. It would be nice to have a reason that correlates to the relationship between momentum and some force, e.g. electron momentum and strong nuclear force. I.e. something should explain the relationship between electron-nuclear-gravitation and the speed of light in a vacuum because otherwise there is no logical relationship between force, energy, and space. Material motion and radiation propagation are related in the speed of light, so there must be some logical relationship between matter and energy that explains the relationship.
I don't mean to sound patronizing, but it really sounds like you're grasping at straws here. I don't know of anything that could be the relationship you're talking about and I don't even understand why you think there has to be one.
And the number 299792458 that humanity has chosen to represent the speed of light in SI units is arbitrary, no way around it, because our choice of units is arbitrary. Just look at how many different unit systems there are in the world: SI, CGS, imperial, atomic, astronomical, cosmological, probably plenty that I've never heard of...
No, no, that's Planck's constant. Planck units are a system of units (like SI units) that are based only on the properties of free space, and thus in some sense are the most "fundamental" or "natural" units to do physics in.brainstorm said:Planck units have something to do with the minimum amount of energy transferred by a given frequency of radiation, which in turn seems to have something to do with the amount of energy released by a unit of electron motion change, right?
No, I don't see how that comes into it at all.brainstorm said:So, this seems to have something to do with the inertia of the electron vis-a-vis the attractive force of a proton, no?
There are two detailed derivations of the equation in the Wikipedia article I linked to. This was not a result of data analysis, nor was it a random inspiration - its origins are well-grounded in electromagnetic theory.brainstorm said:Interesting. This makes me wish I could read equations better qualitatively. This equation looks like the result of loads of data processing and attempts as fitting the data with predictive equations. Or was there a eureka moment of qualitative logic in there somewhere?
Nope. There really is random chance at work at the most basic level of interparticle interactions. Quantum mechanics specifies that, to put it very simply, in situations where multiple outcomes are allowed by the laws of physics, there is no factor that predetermines which outcome will actually occur. Collisions between particles are of this sort; there are a few restrictions imposed by the laws of conservation of momentum and energy, but within the possibilities allowed by those, it's a random choice.brainstorm said:How could it be random? Some factor must govern why and how a molecule "decides" whether to transfer KE to another molecule via contact or radiation, no?
Note that quantum effects are small, so they're most noticeable on very small scales, generally the size of an atom and smaller (roughly speaking). When you work up to molecules, once you take into account the orientation and relative position of the molecules as they collide, often one possible result becomes overwhelmingly more likely than the others.
OK, coolbrainstorm said:aha, thanks. I didn't know how an electron could travel a distance corresponding to the length of a radio wave, but I can see how a free electron in an antenna could.
Well, you don't use the same wave whose frequency you're trying to measure to define the unit of time! If you did that, then the wave would always appear to have the same frequency. But you would find that other physical processes, which normally always take a specific time, would take longer or shorter, and it'd be difficult or impossible to develop a consistent physical theory.brainstorm said:I'm not sure, but it seems to me that time is relative to the wave, because the wave has no fixed time interval in and of itself. So the wavelength can vary according to how the time interval is defined. If a second is longer, red-shifted light would contain the same number of waves as its pre-shift predecessor, right?
Right.brainstorm said:If that second is constant, then the red-shifted light would contain less waves-per-second (lower frequency) than its predecessor, right?
Because other time standards (besides light waves) don't change. For example, an atomic clock. You can set up an atomic clock and a ruler next to a redshifted wave and use them it to measure the wave's frequency and wavelength respectively, and you will always find that the wave travels at the speed c = 299792458 m/s. But you may find that its frequency has changed relative to some other location where you did the same measurement.brainstorm said:How would red-shift be distinguishable from the light slowing down within a constant time interval? If all light waves shifted by the same amount, how would the shift be identifiable as a frequency-shift and not a velocity-shift?
Well, as DaleSpam pointed out, light actually does have inertia, because it has energy. I've been sort of glossing over that point.brainstorm said:The only reason, I guess, would be the inability of the waves to decelerate due to lack of inertia.
That's what everybody thinks at first, but it's really not the same. The true probabilistic nature of QM takes some getting used to.brainstorm said:I have read that in QM electron position is probabilistic, but that is imo like saying human height is variable.
I'm not quite sure what you're getting at with this...brainstorm said:In other words, I don't think it changes the mechanics of how any given electron interacts with its nucleus. I think it's just impossible to specify the exact parameters, such as the exact mass of a given electron, the exact mass of its corresponding nucleus, etc.
