Unraveling the Mystery of Gravity: The Role of Mass in Space-Time Distortion
In summary, the conversation discusses the concept of gravity and how it is caused. The analogy of objects falling into a dent in space-time fabric is used to explain gravity, but it is not a true explanation as it uses the term being defined. The conversation also touches on the use of relativity theory and its role as a symbolic language in understanding gravity. The cause of gravity is still an open question and is thought to be related to the distortion of space-time by matter.
  • #36
DaleSpam said:
Ahh, my apologies, I completely missed that.
Excellent. I look forward to it.
Btw, once you understand the geometric view I think that it will not be very difficult for you to understand the connection between it and the forces view.
To be clear: The graviton would quantize the curvature that GR describes, not some kind of gravitational energy in the manner of a usual force field?
  • #37
I simply don't feel comfortable talking about the properties of gravitons in any fashion without a workable theory of quantum gravity. I was referring to the well-known Newtonian limit of GR, not the rather unknown quantum limit.
  • #38
Understood, and understandable.
  • #39
Frame Dragger said:
I SAID that "why" questions never end well when people expect a science to produce "TRUTH".
Simply rephrase the question as how does mass cause gravity?
Exact same question, without the annoying philosophical implications.
  • #40
This is true, and the answer is: the SET describes how that occurs, but not how mass arises. There is no "Why", only a "How". It's not quite the same question however, because if the person then says, "Well, how does the SET work?", that is a clear question. If they ask what mass really is, then you instnatly recognize a dead-end.
  • #41
Frame Dragger said:
This is true, and the answer is: the SET describes how that occurs, but not how mass arises. There is no "Why", only a "How". It's not quite the same question however, because if the person then says, "Well, how does the SET work?", that is a clear question. If they ask what mass really is, then you instantly recognize a dead-end.
I'm lost on the first part of your post but the last sentence seems not quite right. Mass represents the energy equivalence of matter. I could understand more if you recognised a dead end if they asked what matter really is. Is that what you meant?
  • #42
No... In fact, that would be the bassackwards way of putting it.
mass and energy are equivalent, which really just means the question is: "What is mass/energy and what is inertia/momentum?"
  • #43
Nabeshin said:
I was trying to illustrate that neither picture is more correct, better, or any more real.
This is hogwash. You seem to have forgotten the cornerstone of Einstein's field equations is built on the analogy between the weak gravitational field and the Newtonian gravitational law. Solving the geodesic equations of a spherically symmetric time-independent "perturbed metric" and using the EP, where the inertial and gravitational forces along [tex]r[/tex] implied on a free falling particle are put in an equality, we lead to the fact that the "perturbed tensor" is actually made of Newtonian gravitational potential. So we are introducing in GR the potential stemming from Newton's law of gravitation which explicitly involves forces. Furthermore using the field equation for an empty space and assuming a non-relativistic radial velocity in a Schwartzschild metric, you can lead to the Newtonian gravitational force law. So it seems we have reached a middle ground between two ways of looking at gravity in the context of GR and your claim doesn't sound right at all.
AB
  • #44
What exactly are you trying to say, Altabeh? How does the existence of a Newtonian limit prove that "Your original post seemed to be implying the force description was indeed the "real" description of gravity, which is hogwash." is hogwash? Nabeshin is quite right here.
  • #45
Imo, Nabeshin's claim that neither picture is more real is hogwash because definitely gravity is a force but is looked at another way in GR. After all, we say that gravity is one of the fundamental forces of nature but a theoretical framework that GR seems to construct deos also provide a mechanism by which we can get an equivalence between an "interacting force" and "curvature" and the first being more realistic doesn't deny the curvature approach is correct! From a philosophical point of view, as I earlier said, this is a matter of realization to say which one of them is more realistic. Maybe Nabeshin sees the problem from another angle but I do like to stick to the fact that I can feel the force of gravity every day by looking at things around falling down to the ground due to this force!
B.t.w. "Your original post seemed to be implying the force description was indeed the "real" description of gravity, which is hogwash." seems to have entered in my quote accidently, just a mistake, and it has definitely nothing to do with my post and I'm going to edit it!
AB
  • #46
Imo, Nabeshin's claim that neither picture is more real is hogwash because definitely gravity is a force [...]
You're using strong words to attack a strong position with weak arguments.
Especially as you concede that:
Well, maybe I see the problem from yet another angle. Becuse I'd say that viewing gravity as a force is level with postulating an ether. Hogwash, except for practical reasons, to simplify calculations or facilitate reasoning in certain circumstances.
That's natural philosophy, not physics.
Gravitational force is fictitious.
  • #47
This is hogwash. Neither in GR nor in the Newton's picture there is a theoretical "cause" for
gravity and such a postulation is not even true as is thinking that there is a reason for why spacetime is curved by mass in GR. All comes to whom which theory sounds more realistic and we all just attack each other's views on the subject by our own thoughts\understandings.
And you see that there's been a bunch of "hogwashs" in this thread just because everyone sees the problem from his own angle. Since this could be by itself just an idea, I don't see a problem in it!
So how could physics possibly prove what picture is realistic in case both can be considered as being more real by different people with different viewpoints? This issue is more of philosophy than physics.
Only GR interprets gravity as a fictitious force under some strict circumstances (the non-relativistic velocity, weak gravitational field and etc. will lead to gravity appearing as a real force as in the Newton's theory), so in the classical viewpoint it's still a highly credited force!
AB
  • #48
I've read comments here that refer to Gravity both as a force as warped space-time. Can it be both? A force has a force-carrying particle, and as stated above is the not-yet-observed graviton for Gravity. Does the graviton actually perform the warping of space-time?
  • #49
According to GR, it is geometry, and a pseudo-force. As for the graviton, there was a recent thread about that... a search for active threads in the last 2 weeks should turn it up. One way or the other, gravity is not a force, but what the graviton is... IF it is... well... hypothetical, and unknown.
  • #50
Gravity, and I know this is only in my mind, is the center connection to my past which I feel as mass. This last week I joined my center connection with my Road Glides center connection for a 1500 mile trip around the center connection of this sweet planet we call Earth. :!) I don't know why mass causes gravity but I like thinking of it the other way, why does gravity cause mass.
  • #51
petm1 said:
...I like thinking of it the other way, why does gravity cause mass.
Gravity does not cause mass.
  • #52
"The point is that the raw material doesn't really have to come from anywhere. When you have strong gravitational fields, they can create matter." Stephen Hawking
I Found this quote in Cosmology forum today?:wink:
  • #53
Matter, not new mass.
  • #54
Exactly.
  • #55
petm1 said:
Exactly.
OK then we're on the same page.
  • #56
I'm still a little confused. In the time line of big bang mass does not come into play until the quark epoch with matter in the form of particles following and all formed from a gravitational singularity. But of course this is looking back through time. :confused:
  • #57
Energy and momentum existed, but not matter. I suppose there is also the issue of GUT theories and no SSB...
  • #58
Gravity describes the geometry of space/time. The way that matter formed from this dilating gravitational singularity we call big bang into our visible universe, in my mind, makes gravity the cause and mass, the trail through the past to that dilating motion, the effect. :confused: Is this equivalent to mass causes gravity?
  • #59
How about this approach...
Imagine a laticework of an "infinite" (so-to-speak as we do not know if the universe is infinite) of points arranged in a zillion little cubelets. I cannot draw this. I wish I could.
Then imagine objects with mass in the latticework and displacing it outward creating compression towards the center of the mass. Hence, space is displaced outward and the tendency is to push obects in. This would be the gravity. The volume of the object is not relavant, only the mass. Ithink someone above talked about a "dent" in space time causing distortion. That's as good as anything else.
