- 7,315
- 11,130
Thanks, it says to do so only temporarily, but still a good point. Of course, remember to reinstall ASAP.jedishrfu said:This page says if you encounter any problems with anaconda install on windows then disable the virus scanner (scary to me) and try again:
https://docs.continuum.io/anaconda/install#anaconda-for-windows-install
It may be that the virus scanner flagged some key file and wouldn't let it get installed.
Just what a virus needs.WWGD said:it says to do so only temporarily
Borg said:Just what a virus needs.
lol. These aren't the safe applications you're looking for.jedishrfu said:The old jedi mind trick trick.
Borg said:lol. These aren't the safe applications you're looking for.
But if the source is trustworthy?Borg said:Just what a virus needs.
Even a trustworthy source could have a virus. Software should never be telling you to disable your virus scanner. If so, it's either a virus or they don't know what they're doing. I wouldn't trust either scenario.WWGD said:But if the source is trustworthy?
There's no simple way of detecting all viruses like that. Each virus has it's own way of infiltrating a system.WWGD said:Do you know a way of using SysInternals/Process Explorer to detect a virus? I have been trying for a while, following online instructions without success.
jedishrfu said:Viruses don't always live in identifiable processes sometime they co-opt a legitimate process and run under its umbrella.
If you set a system restore point right before doing all of this, and you did happen to mess up... could that undo the changes you made ?Routaran said:If you mess up and set deny permissions on a valid system file, you will kill windows. Unless you keep a record of your changes so you can undo them, you will end up having to wipe your computer to fix the problem.
No, system restore backs up portions of your windows registry. It does not affect your file system.OCR said:If you set a system restore point right before doing all of this, and you did happen to mess up... could that undo the changes you made ?
I know you'd still have the malicious software, but would a system restore operation even run, or work... at all ?
[COLOR=#black] ..[/COLOR]←[COLOR=#black]...[/COLOR] "... and if you haven't completely destroyed windows by now ..." [COLOR=#black]... [/COLOR] lol
There could be several reasons for a slow download, such as a poor internet connection, server issues, or a large file size. It is best to check your internet speed and make sure there are no interruptions in your connection. If the problem persists, you can try downloading from a different server or at a different time.
If your download stops or fails, you can try restarting the download or using a download manager to resume the download. You can also check your internet connection and try downloading from a different server.
The appearance of the Anaconda download may vary depending on your operating system and browser. As long as you downloaded the correct file for your system, the appearance should not affect its functionality.
Anaconda is a reputable and widely used platform for data science and machine learning, so you can be confident that the download is safe. However, it is always a good practice to download from the official website and check the file's integrity using a checksum or virus scan.
Yes, Anaconda offers options for customizing your installation, such as choosing specific packages or adding additional environments. You can also update or modify your installation at any time using the Anaconda Navigator or command line.
