?. They don't "seem" to be. You seem to be confusing what you heard, that or what you heard is wrong. We can't see (normal) stars at cosmological distances, they're too small/dim. We do see galaxies and supernovae. We are able to measure the redshift of the light we detect from them. IF you were to (incorrectly) plug these redshifts into the equation for Doppler shift, we would NOT get a velocity greater than the speed of light.
For instance given a redshift, z, of 8.6, if γ=v/c the doppler equation 1+z = √((1+γ)/(1-γ)) gives 97.85%. A redshift of 100 would give 99.98%. It IS reasonable to ASSUME that if we measure an object with a cosmological redshift of 8.6, which would mean that the light we are NOW measuring was emitted 13+ billion years ago, it IS reasonable to assume that that object is NOW beyond our ability to ever see again, and its distance is increasing at faster than the speed of light, c. In fact, I don't know of any theories of cosmology which would not accept that as being 'correct' ("true"). This is a difficult subject, especially since the words we use are often used in different ways. Distance, speed, velocity, even universe all have various DIFFERENT meanings depending on context. Most of the confusion arises in thinking that there is a single (intuitive) meaning of these concepts. For instance, most cosmologists accept the fact that the Universe is much larger than our Observable Universe, and many accept the assumption that it is infinite. The Observable Universe is what we can (or could or will ever) see. Speaking about what goes on outside of that region is more philosophy/religion than science (at least the way I define science).
I should note that a cosmological redshift of the 'most distant' object ever measured is 8.6, although I am not sure if that has been accepted by the consensus yet. We'll NEVER see something with a cosmological z of 100!
