Why Does the Order of Transformations Affect the Graph of a Function?
The discussion centers on understanding the order of transformations for functions in precalculus. A student is confused about why their graph differs from the teacher's, particularly regarding the sequence of reflecting and shifting transformations. The teacher suggests reflecting last, while another participant argues that the order depends on whether transformations are applied inside or outside the function. The correct approach involves applying transformations in a specific order, following standard mathematical operations. Ultimately, mastering this order is crucial for accurately graphing transformed functions.
modonnell121
Okay so I've done very well in college so far, and I thought I was at least decent at math, but I just started this precalculus class and I'm having an issue.
I basically don't know, and can't get a straight answer about how to handle functions that have multiple transformations going on. This is not a homework question, but it is a perfect example of my issue, so I'm posting it.
My answer is the function sketched below and to the left of the printed one, except I would have shifted it down one but there is no room on the graph, as you can see. I must be that far off, huh? The teacher's answer is like mine but shifted up one unit. This is apparently because he reflected it after shifting, while I reflected first. In his email explaining why he did this he told me "It's always best to do the reflecting last as it is the last thing that happended to the function in the transformation process." WHAT?
How do I know the order, what do I DO? Please someone help me.
Mathematics news on Phys.org
I believe your teacher is wrong, and you are correct (unless I'm suffering from brain failure).
In the case of y= -f(x+2) -1 you must "reflect" f(x+2) before subtracting 1! This graph should be 1 below y= -f(x+2)!
If it was y= - [f(x+2) -1] you would "reflect" afterwords like your teacher did (ultimately shifting up 1, because y = - [f(x+2) -1] = -f(x+2) + 1).
Cool, I thought I was right. But can you explain how I determine the order to do the transformations in general?
Sorry, didn't see your reply until today. There is a specific order of operations, with a few different rules to get used to.
For functions (such as f(x) or g(x)), you apply the function to whatever is within the parenthesis in the function declaration.
f(x) you apply the function f to x
f(x+2) you apply the function f to x+2. in other words you replace the value for x with x+2
IF f(x) = 2x THEN f(x+2) = 2(x+2)
IF f(x) = 2x+1 THEN f(x+2) = 2(x+2) + 1 etc.
Then you follow the standard order of operations.
IF y=f(x) + 1 you calculate f(x) then add in 1 to calculate y.
IF y=-f(x) + 1 you calculate -f(x) then add in 1 to calculate y.
IF y=-[f(x) + 1] you calculate f(x), add in 1, and THEN flip the sign to determine your y value.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
