Why does this step response overshoot?
The discussion revolves around the unexpected overshoot in the step response of a closed-loop transfer function, despite correct pole placement. It highlights that the presence of a left-hand plane (LHP) zero can significantly influence the system's transient response, contributing to the observed overshoot. Users suggest that inserting a pole at the same location as the zero could mitigate this effect. The conversation also touches on the challenges of achieving specific response criteria, such as 0% overshoot and a settling time under 1 second, using only integral (I) control. Overall, the interaction emphasizes the importance of both poles and zeros in system dynamics and control design.
215
I have this transfer function which i don't know why it is overshooting due to an step input.
http://snag.gy/Vh1SM.jpg
Could someone explain why it does that.
It's it a close loop transfer function, where I've designed a controller for it, but for some reason, eventhoug all my poles are placed correctly, it is not possible to get the response i want to.
With the given transfer function there is no overshoot.
Wolfram alpha agrees!
Oops, there is too a small overshoot. I couldn't see it on wolfram. It's due to the zero at s = -1.513. Sorry!
You can cancel it by inserting a pole at the same point (s = - 1.513).
But how come does zeroes apply overshoot? I thought it was only poles which affected the system
You should check your entry. It does have overshoot.
The transient response of your system is not only determined by its poles. You have a LHP zero as well, which can have a significant impact on the overshoot of the step response of your system.
Quick Google search for 'poles zeros transient' turned up:
http://courses.engr.illinois.edu/ece486/documents/lecture_notes/effects_zero_pole.pdf
but what criteria should i apply for determining the zeroes, and how does it affect the system. I mean it is still a LHP zero? so bad can't it be
How should i using a PID controlle be able to adjust the Zero location, while i am adjusting the location of the pole.
You need to describe your problem more fully, not just talk about an isolated transfer function. What is your plant and what are the response criteria?
I tried to make a general problem, but seems to have forgotten where it began at.
I posted my problem on another forum.
http://snag.gy/OqhxH.jpg
I hope this helps.
My repsponse criterias is that I want an overshoot to be 0% and settling time be under 1 sec.
Using Matlab tuning application i managed to do with only the I part of the controller. The problem is though I've read a lot of places that it is not recomended to use just I or D regulators.
