I Why does wind blow leaves in circles?
Strong gusts of wind often cause leaves to move in circular patterns due to the formation of eddies, which are created when air flows around obstacles like buildings or trees. These eddies can trap leaves, causing them to spiral rather than move in a straight line. The upward movement of air in these eddies is slower than the rate at which leaves settle, allowing them to circulate before eventually landing. Additionally, the presence of obstacles disrupts the airflow, leading to turbulence that contributes to this circular motion. Overall, the interaction between wind and physical structures results in the characteristic swirling of leaves.
Josh0768
TL;DR Summary
Earlier today I realized that, when a strong gust of wind would blow through my area, it would pick up leaves off the ground and typically blow them in circular patterns, and typically the leaves would go in at least several complete circles before coming to rest back down on the ground. Why is this? How come these leaves don’t move in a translational fashion?
Because the wind doesn't.
Google 'eddies' and 'whirlwind'
Likes davenn
You do not notice the few leaves that blow by with the wind. It is the ones that accumulate in the eddy that you focus on. When air enters an eddy behind an obstacle, or at the corner of a building, it may spiral upwards to escape from behind that obstacle. Leaves that enter the eddy may be trapped because the air in the eddy rises slower than the leaves settle.
Josh0768 said:
Summary:: Why does wind blow leaves in circles?
On a perfectly flat Earth with no hills or smaller obstructions, you could imagine large regions in which the air flowed in a straight line. But absolutely anything can upset that. In the same way that your hand moving across the washing up bowl causes eddies in the suds on the top, trees, fences etc etc make the same thing happen.
There's a basic principle that the physical World is becoming more and more disorganised (taken as a whole) and turbulence is always likely to occur in moving fluids.
Likes Josh0768
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
