Why don't black holes look like neutron stars to outside observer?
apocope
Yesterday, I read about Hawking's new proposal regarding the firewall paradox.
A more general thought about standard black holes occurred to me. Black holes including stellar black holes are of course always presented as if the event horizon is an invisible barrier, which the unfortunate astronaut is won't to cross in thought experiments rather unremarkably (perhaps to be incinerated immediately, or not, but at least getting there is unremarkable). In the thought experiments of course the outside of observer never sees the astronaut actually get to the event horizon because of gravitational time dilation. It is unclear to me why the same would not hold for the original collapsing mass itself. It seems runaway time dilation should occur the moment the seed singularity forms.
I assume the singularity starts in the dense core and begins absorbing successive outer layers with the event horizon expanding outward. Why would an outside observer ever be able to see the end result and not a degenerate star just starting to implode?
I'm not a specialist, though I do have a BS in physics, so perhaps I am missing something.
Well, the poor chap does get Spaghettified first...
http://en.wikipedia.org/wiki/Black_hole#Gravitational_collapse
While most of the energy released during gravitational collapse is emitted very quickly, an outside observer does not actually see the end of this process. Even though the collapse takes a finite amount of time from the reference frame of infalling matter, a distant observer sees the infalling material slow and halt just above the event horizon, due to gravitational time dilation. Light from the collapsing material takes longer and longer to reach the observer, with the light emitted just before the event horizon forms delayed an infinite amount of time. Thus the external observer never sees the formation of the event horizon; instead, the collapsing material seems to become dimmer and increasingly red-shifted, eventually fading away.[75]
This help?
Thanks Enigman,
I was under the impression that spaghettification would happen after our unlucky astronaut crossed the event horizon...
Enigman said:
Enigman said:
This help?
Yes. So it does appear that, to an outside observer, at least a stellar black hole would appear as a solid mass, with a layer of the degenerate star just above the event horizon. Is that correct? If so, he could never reach the event horizon because he would be in a reference frame outside that of the layer appearing to remain. As he got closer, the shell would probably get brighter and he would be exposed to more and more of the radiation... Is this a more realistic version of the unlucky astronaut?
Of course, this would apply to the case of stellar collapse, but it seems the same would be true of almost any scenario leading to a singularity. To an outside an observer, the collision of two stellar black holes would never be complete, and the event horizon would remain covered in a shell. I suppose an exception could be black holes arising from particle collisions...
It strikes me that this brick wall around at least stellar black holes could mitigate against the firewall paradox, but of course I suppose that would have already been noticed, but it certainly helps me understand what a black hole might look like from the outside.
There is no "seed singularity"; the singularity is not the same as the event horizon. See below.
No; the singularity doesn't form until the entire collapsing star has reached zero radius and infinite density. When the event horizon forms at the center of the star, the density there is still finite. The horizon reaches the surface of the star just as that surface is falling inward past the star's Schwarzschild radius (2GM/c^2).
It depends on the size of the hole. For a stellar-mass black hole, tidal gravity at the horizon is strong enough that any normal material would be torn apart by the time it reached there. For a supermassive black hole (like the one at the center of our galaxy), tidal gravity at the horizon is small enough that an astronaut wouldn't get spaghettified until he was well inside the horizon.
No. To an outside observer that remains "hovering" at the same altitude, high above the star, the star will seem to collapse more and more slowly as it gets closer and closer to its Schwarzschild radius; it will never appear static. Its material will still appear as ordinary star material (but collapsing, of course).
To an observer who falls inward towards the horizon after it forms, things are different. See below.
No; it's perfectly possible for an outside observer to fall through the horizon after the star has done so. If he does, then when he crosses the horizon, he will see light from the star when it crossed the horizon. As he gets further and further inside the horizon, he will see light from further (meaning, further inside the horizon) portions of the star's collapse, up to a point; at some point, he himself will hit the singularity, before light from the final portion of the star's collapse to the singularity reaches him.
Not classically, no. Classically, there is nothing special about the horizon. The "firewall" controversy is about how quantum effects change the classical picture; but whatever those changes are, they don't amount to a classical "shell" around the horizon, since there isn't one, as above.
If the observer says outside the horizon, yes.
Not really. See above.
According to our best current understanding, there can't be any; the smallest mass a black hole can have is the Planck mass, which is much larger than any elementary particle mass.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
