Why don't stars explode? What holds them together?
  • Thread starter Thread starter alancj
    Stars
Stars do not explode due to a balance between the gravitational force pulling inward and the pressure from nuclear fusion pushing outward. The Sun's mass generates a strong gravitational field, sufficient to hold together vast amounts of hydrogen undergoing fusion. While only a small portion of the gas in a star is actively fusing, the energy produced maintains the necessary pressure to counteract gravitational collapse. When this balance is disrupted, such as in a supernova, gravity can overpower the fusion energy, leading to an explosion. Understanding these dynamics involves complex equations and concepts from astrophysics, highlighting the intricate relationship between mass, pressure, and gravitational forces in stellar stability.
alancj
I do know that stars explode on occasion... but I don't understand how gravity could possibly have enough force (attraction or whatever you want to call it) to hold trillions and trillions and trillions of tons of hydrogen undergoing nuclear fusion. It seems to me that there would be vastly more pressure to expand outward than to hold it together.
Can anybody point me towards some math that would show that a Sun's estimated mass would have enough gravity to keep things together?
Also according to my high school science book's explanation, stars form from vast clouds of gas that eventually compress enough (do to mutual attraction between particles) to initiate nuclear fusion. It would seem that clouds of gas would form (brought together by gravity) but the gas would resist further compression, and remain as simple clouds (or one big giant cloud).
Can anyone help my confusion here?
Thanks,
Alan
Astronomy news on Phys.org
only a little bit of the gas is undergoing nuclear fusion in the very center
of the star
that why our star the sun will last for billions of years
while the sun looks like a big ball of fire the real burning is only only happening
in a small part of it
gravity is a hard thing to understand and even the best minds in physics
are just starting to try to understand it
thats why some think 95% of the mass in the univerce is missing [dark matter] or maybe we just don't understand gravity very well YET!
Our Sun has a mass about 1 million times greater than that of the Earth, which translates into BIG gravity.
The sun is stable precisely because the outward pressure produced by the fusion process is exactly balanced by the inward gravitational force.
Well I know that things are obviously in equilibrium, I'm looking more for an accounting of all the forces. Because if gravity equals 10 and nuclear reaction and heat equals 1000 then you know that some things are amiss.
convection...
look for a textbook by Ostlie and Carroll...it will explain it all in there
There's like 4 pressure equations(keeps teh star togeterh like how max eq'n are used for E&M)
think the book is called intro to astrophysics.
I don't know the answer to your question. But I do know that a = b for the sun. I've been told that when the forces get out of balance, as in a nova or supernova explosion, it's gravity and not the heat that is the larger of the two. It's easy to see why. Nuclear reactions may die out over time, but gravity is forever.
According to Einstein gravity is caused by a number of things, pressure, mass and density energy, energy flux, etc, curving space-time. The Sun curves so much space that there is enough gravity to keep it together. The nuclear reaction is at the center of the star and then the rest of it will be held together with gravity. The energy escapes out the star and the extra mass goes to the mass of a shell of a star.
Alan
One way of lokkoing at this is comparing the Sun's gravitational binding energy(the amount of energy needed to pull the sun completely apart) to the amount of energy it produces through fusion.
The Sun's gravitational binding energy is equal to about 2.24 x 1043 This is about equal to the amount of energy it produces through fusion in 150 million years.
Hmm, the edit feature doesn't seem to be working for me right now, but that 150 million year figure should be 15 million years.
That reminds me of a joke:
A. The sun will die out in 5 billion years.
B. Did you say 5 billion years?
A. Yes.
B. Thank goodness, I though I heard you say 5 million years.
Here's one way to think about it:
Gravity likes to pull things together
Hydrogen doesn't like to fuse into helium... it would rather just sit around being hydrogen.
But, hydrogen dislikes being packed very tightly even more than it dislikes fusing into helium. So, under considerable duress, hydrogen will fuse to relieve the packing problem.
So that's why a cloud of gas might erupt into a star.
But, remember that hydrogen doesn't like to fuse. So, only enough fusion will happen to combat the problem of being excessively packed together. (roughly)
So that's why the star generally doesn't explode.
Why should nuclear fusion produce a repulsive force?
To grossly oversimplify that, the energy produced seeks equillibrium with its environment... violently.
The nuclear fussion reactions dosn't fuse hydergon and helium togther; it converts the hydrogen into helium.
True at our sun's level of activity. Farther down the line, the helium-3 will fuse into helium-4, then lithium, etc.. I can't recall the exact sequence right now.
Because it emits a lot of energy.
When the photons form at the Sun's core it take it about 1,000,000 years to get to the surface(so the sun's core is 1millon light-years away).I think whatever takes light to get 1 millon years to get to the surface is probally whould the thing that's holding it togther.
Nuclear fusion doesn't itself provide a repulsive force, it provides energy to maintain the pressure balance inside the star. The "force" that holds up a star like the sun is the pressure of the gas of which the star is made (which, ultimately, is electromagnetic) and the magnitude of this pressure is dependent on temperature. A balance can be maintained as long as the gas is hot, but if the star is radiating energy away, then it needs an energy source to keep from cooling. In most cases, fusion is this energy source.
Let's not confuse diffusion time with a measure of distance. "Light year" refers to the distance that light travels in a year while freely propagating in a vacuum. The distance from the sun's core to its surface is actually around one ten millionth of a light year.
You could look at it that way. The random walk of a photon inside a star is a direct result of its interactions with the gas. The gas is also the ultimate source of the pressure for stars like the sun. However, for heavier stars, the pressure of the light itself can be important in supporting the star against gravity.
That was just a joke lol
Most of the lithium in the universe was produced by the Big Bang and cosmic ray spallation. After the hydrogen in its core is exhausted, a star will, if it's heavy enough, then begin the triple-alpha process, which converts helium into carbon.
Thanks, Tiger. I knew that there was something wrong with my post. Those sequential thingies always mess me up. :redface:
Some Lithium could be produced within about three minutes of the big bang, but most is the cosmic ray-to carbon collisions after carbon is formed many years after the big bang from reactions in the cores of stars.
From: http://www.astro.ucla.edu/~wright/BBNS.html" we get that:
However, the lack of stable nuclei with atomic weights of 5 or 8 limited the Big Bang to producing hydrogen and helium. Most lithium and beryllium is produced by cosmic ray collisions breaking up some of the carbon produced in stars.
And from http://astron.berkeley.edu/~mwhite/darkmatter/bbn.html" we find that formation of Lithium first requires tritium and deuterium:
In a short time interval, protons and neutrons collided to produce deuterium (one proton bound to one neutron). Most of the deuterium then collided with other protons and neutrons to produce helium and a small amount of tritium (one proton and two neutrons). Lithium 7 could also arise form the coalescence of one tritium and two deuterium nuclei.
and the neat chart near the top of that page shows one H isotope, two He isotopes and Li.
So, if that's the case and order of formation, when do we consider the "big bang" to be in process? One second, one minute, three minutes (as in the book name) ? This is just a general (and pickey) question that I haven't seen brought up before; how much time after zero is the BB still considered to be in process?..:confused: Anyone answer.
How are you distinguishing this from the cosmic ray spallation I referred to? Or are you just expanding on what I said?
I think it's pretty arbitrary. In this case, I suspect that they were trying to distinguish it from stellar nucleosynthesis. Since it was one of the primary predictions of the Big Bang Theory, they just called it "Big Bang Nucleosynthesis".
Well those trillions and trillions and trillions of tons (~1.9891×1030 kg (332 950 Earth masses)) produce a strong gravitational field. Remember, it is strong enough to keep planets in orbit, which are millions of miles away.
The pressure comes from the intense heat/temperature which comes from the fusion reactions.
Fusion reactions produce energy on the order of 1 MeV and at 11605 K/ev, that's about 11 billion K. However, only a fraction of mass is fusing at a given time, so that kinetic energy of the fusion reactants is dissipated quickly to the various atoms and electrons nearby. Temperature of the sun's core is estimated to be ~13.6 MK, and the corona temperature is about 5 MK, while the photosphere 'surface' temperature is about 5800 K.
For information on pp and CNO chain reactions see -
http://csep10.phys.utk.edu/astr162/lect/energy/cno-pp.html
http://burro.astr.cwru.edu/Academics/Astr221/StarPhys/ppchain.html
http://www.shef.ac.uk/physics/people/vdhillon/teaching/phy213/phy213_fusion3.html
Re: Li production (is it necessary that most(?) Li was formed around time of BB as opposed to stars later on or novae?)
p + 9Be -> 4He + 6Li
d + 4He -> 6Li
t + 6Li -> 7Li + d (or p +n)
There is a paper "Influence of Gravity Waves on the Internal Rotation and Li Abundance of Solar-Type Stars" by Corinne Charbonnel and Suzanne Talon in Science mag, but I can't access it since I am not a member. Anyone read this?
Ann Merchant Boesgaard. (http://www.ifa.hawaii.edu/~boes/) is looking at Li abundance in stars.
Just expanding when looking for probable sources for Li found. No distinction from your post.
That makes sense, the distinction allows two seperate, and logical, processes to be discussed. Any stellar nucleosynthesis wouldn't have much to do with the big bang.(Duh!)..:rolleyes:
See posts # 21, 23 and 24.
I think your point is a good one, though. In general, we talk about the "Big Bang" rather loosely, but what does we even mean? No current theory can confidently describe all the way back to t=0 (at which the term "Big Bang" would be completely unambiguous), so it must only be referring to some arbitrary set of times during which the universe was much smaller than its current size. In practice, I think people use it to describe any period of time during which we can't directly observe objects, which would mean anything before recombination. This may be the current meaning, but I suspect that, like "high redshift", the term has been evolving with time.
I doesn't know what we does mean...:smile: :smile: :biggrin: :confused:
(slow night)
the answere:
stars are in a state of hydrostatic equallibrium. outward radiative pressure from photons and nuetrinos emitted in he core are balanced by the inward force of gravity.:smile:
  • #31
So are we stating that the inward force of gravity, squeeze's photons out from the inner core, similar, like a "wet sponge" expelling water when squeezed, so to speak?
  • #32
Photons are only the dominant source of pressure in stars much more massive than the sun. In most stars, it is the particles themselves that are doing the pushing, not the photons (and certainly not the neutrinos).
  • #33
While this is technically true, as SpaceTiger pointed out, radiation pressure is insignificant in the case of the sun.
I whipped this up in Matlab real quick to demonstrate. The graph is on a log scale, so the 10^# you see on the y-axis is the same as that part in scientific notation. it had to be log scale for the gas pressure to even be noticeable on the graph. A difference of 10^4 is a factor of 10,000 difference between the two.
12K
12K
