Why integrate electric potential from infinity to a point inside a sphere
8 replies · 3K views · last reply
UMath1
In the example my textbook has, the electric potential is calculating by integrating the electric field from infinity to R, radius of sphere, and then integrating the electric field from R to r, radius of point inside sphere. What I don't understand is why is the field integrated from infinity to r, why not 0 to r? How do you decide on the reference point? In an uniform electric field, the potential is calculated by integrating from to 0 to r.
All kinds of potential have an arbitrary zero point, which is essentially a constant of integration. Infinity is just a handy choice of a zero point. Since the field of a charge drops off to 0 at infinity, setting a reference point at infinity is like setting a 0 potential reference point where there is no charge at all.
What about if you integrated the field from r=0 to r=R, radius of sphere? Why would that ot give you the right answer? Conceptually what is the difference in value?
You could certainly do that. The result would differ by a constant from the usual formula, which is fine. It would simply mean that you are taking the center as your reference instead of infinity.
So it's just that integrating from infinity is more convenient as the voltage at infinity would be zero, correct?
Khashishi said:
You might find a small problem at r=0.
I think that he is considering a sphere of charge, not a point charge. So there shouldn't be a problem at r=0.
