Why is dichloromethane a good organic solvent?
  • Thread starter Thread starter birdstudyphys
    Organic Solvent
Dichloromethane (DCM) and water are both polar molecules, but DCM's lower polarity allows it to mix more effectively with higher weight alcohols compared to water. While water is highly polar, DCM is only slightly polar, which contributes to its better miscibility with organic compounds. DCM's density makes it advantageous in laboratory settings, as it separates easily from water in a separatory funnel and is simple to evaporate. Despite its utility as a solvent, DCM is toxic, though it is considered less harmful than other chlorinated ethers. Additionally, DCM's diffusivity in water is higher than that of water in DCM, making it a suitable solvent for hydrophobic polymers like PLA.
birdstudyphys
I was working on my chem lab, this question occurred to me. Water and dichloromethane are both polar molecule. However, dichloromethane is able to mix with alcohols much better than water. Is there a polarity difference that caused the miscibility to be different?
Chemistry news on Phys.org
Of course you are talking about higher weight alcohols, not CH3OH or C2H5OH, which are completely miscible with water. However CH2Cl2 is not as polar as water so it mix better than water with organic compounds.
Yeh. CH2Cl2 is barely polar actually since C-Cl has deltaEN=0.5 where C-H gives a 0.4.
Much less polar than water for sure.. Well that explains it. Thanks. I was totally misled by my weird thinking... Egrrr.
DCM is also an excellent solvent for convenient reasons like being more dense than water so it will be on the bottom in a separatory funnel if you do an aqueous workup and it is also easy to evaporate.
However it is toxic, though the least of the chlorinated ethers. CH2Cl2 is partially miscible in water (it is not polar) , but its diffusivity in water is higher that water in CH2Cl2. IF working with hydrophobic polymers, it tends to be in general a good solvent. Specially for PLA.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
