Why is earth pin longer than other two in a plug top?
  • Thread starter Thread starter Abhishakes
    Earth Pin
The earth pin in a plug top is longer than the live and neutral pins to ensure it connects first, providing grounding before the circuit is completed, which enhances safety during a short circuit. This design also facilitates the use of shuttered sockets, preventing objects from being inserted into live ports until the earth pin is engaged. However, there are concerns regarding the effectiveness of these shutters, as they can be manipulated by tools or small objects, potentially exposing users to risk. The simplicity of the three-pin design is praised, as it effectively directs current through the earth pin in the event of a fault. Overall, the longer earth pin serves a crucial role in electrical safety.
Abhishakes
Why is Earth pin longer than other two in a plug top?
By "plug top" do you mean a regular electrical plug, like this:
http://www.worldofstock.com/slides/BEN2097.jpg
If so then the reason the ground (or earth) prong is longer is simply so that it is connected before the live prongs. That way if there is a short you know you are grounded before there is a circuit.
Sorry if I misunderstood and you meant something more complex.
A byproduct of this is the use of shuttered sockets. Here in the UK (presumably in other countries too) many wall sockets have shutters on the live and neutral connectors to prevent children (well, electricians too!) from sticking various objects into the socket and shocking themselves. By taking advantage of the longer pin and using it to open the shutters, you ensure that the live and neutral ports are only open just before the relevant pins are inserted.
Of course there's still a flaw with this. Electricians amonst others are prone to holding open the shutters through the ground port with a screwdriver; if they can do it so surely can children! Plus as the shutters open before the pins are fully engaged, you can fit small objects such as paper clips into them.
Both of the above
I think the three pin shuttered design is remarkably good for it's simplicity.
Ok, I think you know little Electrical stuff. In Electrical, current always flow through the easiest path that is lesser resistance. if you study about resistivity you can understand that resistivity is inversely proportional to the area (if area increases - resistivity will decrease). When you have short circuit the resistivity of the Earth pin is lesser (area is more) so the current will flow through this pin and will reach the ground. you can avoid shock.
To an extent, the Earth pin is only slightly longer.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
