Why is radiance defined per projected area normal to the beam direction?
Radiance is defined as radiant flux per solid angle per projected area normal to the beam direction to ensure consistency and meaningfulness in measurements. The projection of the surface area normal to the beam accounts for the angle between the light direction and the surface, which affects the perceived intensity of light. If radiance were defined without this projection, it would vary based on the orientation of the surface, making it less useful as a universal property of light. An example illustrates that without projection, measured radiance would be lower for angles near the horizon due to the Tilting principle, while projection maintains a constant value across the hemisphere. Thus, radiance is fundamentally a property of light, independent of surface orientation.
brightlint
Radiance is defined as radiant flux per solid angle per projected area normal to the beam direction: ##L = \frac{d^2 \Phi}{d \vec\omega \cdot d A_\perp}## where ##A_\perp = A \cos \theta## and ##\theta## is the angle between the beam direction ##\vec\omega## and the surface normal. I kind of understand that radiance is simply the infinitesimal flux ##d\Phi## contained in the infinitesimal cone/ray which is described by the infinitesimal solid angle and the surface segment ##d A##. However I don't understand why it's necessary to project the surface segment normal to the beam. Why would ##L = \frac{d^2 \Phi}{d \vec\omega \cdot d A}## be a bad definition of radiance?
Then L would depend on the definition of your area and its orientation relative to the flux. The number alone would become meaningless.
I'm still having trouble to see why that would be a problem. I would be glad if you or someone else could illustrate it with an example like this:
Suppose there is a surface segment ##d A## inside a sphere and the sphere emits light on the inside like a Lambertian radiator. If I measure the incident radiance at the surface segment ##d A## coming from a certain direction ##d \vec\omega## without the projection of ##dA## normal to the beam, then the measured value would be small for directions near the horizon because of the Tilting principle. However, if I project the surface segment normal to the beam, then the radiance would be constant across the whole hemisphere.
Is this correct so far? Why would it be meaningless if the radiance would change depending on the direction?
Radiance is supposed to be a property of the light, not a property of the interaction of light with some (not necessarily real!) surface with some specific orientation.
Why don’t we use a differential area normal to the beam in the first place, instead of projecting a non-normal one?
Besides that, radiance is often described as an measure for how bright an object appears, wouldn't that be a property of the interaction of light with a surface?
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
