Why is Rieke Mg used in Grignard reactions?
  • Thread starter Entropia
  • Tags
    Reactions
In summary, "Mg turnings" are used in Grignard reactions instead of "regular" Mg because they have a lot of surface area which can speed up the oxidative addition step. The Grignard reaction is a reaction between an alkyl group and a halide that produces isopropyl alcohol. Elemental magnesium is very reactive and the surface oxidizes almost immediately in air, so using Mg turnings can help speed up the process.
Entropia
1,474
Why are "Mg turnings" used in Grignard reactions instead of "regular" Mg?
What is so special about Mg turnings?
Chemistry news on Phys.org
Mg turnings are regular Mg. It's just chopped and scraped up into little bits. Why do you think little bits would be better then one big ingot of magnesium?
as it may inc surface area for more effective rxn
Yup.
It can be experimentally hard to get the oxidative addition step of a grignard reaction to go. Cutting the Mg into smaller and smaller strips increases the surface are and can often speed this up. If this doesn't work, you can use Reicke Mg, which generates the elemental magnesium in situ, resulting in basically a very, very fine powder.
What is a Grignard reaction?
You may remember it from your sophomore O. Chem. class. Basically, a magnesium inserts itself into a bond between an alkyl group and a halide, then adds to a carbonyl. So methyl bromide reacted with magnesium will react with acetaldehyde to produce isopropyl alcohol.
Elemental magnesium is very reactive and the surface oxidizes almost immediately in air. If you use the turnings then you can squash them a little bit in order to expose some of the interior metal which has not yet been oxidized. It's a nifty trick and works great!
Usually if the bottle of Mg turnings is old you'd have to activate it somehow, usually with dilute HCl and washing, but the exact method is tedious. I like to get a fresh bottle of Mg powder (200 mesh+) and try not to open it in air if I can help it, or keep the exposure to a minimum. Fresh, active powder beats big turnings any day.
edit: I see someone mention Riecke Mg. Making this is an extreme pain (reducing MgCl2 with potassium in THF), but it's as active as you can get, maybe too reactive even. Can you buy this stuff yet? Surely it would be extremely hazardous to ship.
Sure the powder is better if you have access to a dry box to keep it in. A lot of labs don't have those though, and it's really not pratical for instructional labs.
Another trick is to add a few drops of 1,2-dibromoethane. The dibromoethane inserts much faster than most substrates and essentially digs pores into the Mg, thereby increasing the surface area of un-oxidized Mg. You can also try adding a couple of crystals of iodine to essentially do the same thing. The iodine trick has never worked for me, but the 1,2-dibromoethane works very well and has never failed me.
You really just need to get the oxidative insertion started, then it tends to propagate on its own because the reaction continually exposes more Mg metal.
Actually, I think you can buy it now. Not that I'd trust it, I'd just make my own if other ways of activating Mg wouldn't work. Usually stirring the turings under argon overnight works fine. If not that, then 1,2-dibromoethane usually does the trick.
this is the kind of answer i was looking for. what i meant by 'regular mg' was elemental mg.
-thanks!
So ... what is Riecke Mg?
Rieke Mg (along with Riecke Zn, Al, and other metals) is simply a nanosized powder with huge surface area and virtually no oxide (it's named after Rueben Rieke)
you start with a halide salt of your metal suspended in dry THF (or glyme or diglyme) under Argon
then you gradually add potassium or lithium metal (sometimes with some napthalene or anthracene as a charge transfer agent to make it a little less vigorous) to reduce your metal and leave potassium or lithium halide
you are left with a suspension of your metal in dry THF along with the alkaline halide
usually the K or Li halide is quite insoluble in the organic solvent and inert to whatever organic reaction you are doing (like a grignard) so it's usually just left into be washed away later
Here is one of his webpages http://www.unl.edu/cmra/faculty/rieke.html
Related to Why is Rieke Mg used in Grignard reactions?
1. What is a Grignard reaction?
A Grignard reaction is a type of chemical reaction that involves the use of a Grignard reagent, which is a compound containing a carbon-magnesium bond, to react with an organic halide. This creates a new carbon-carbon bond and results in the formation of a new organic compound.
2. How is magnesium used in Grignard reactions?
Magnesium is used as the key component in creating the Grignard reagent. It reacts with an organic halide to form an organomagnesium compound, which then undergoes further reactions to form the desired product.
3. What are the applications of Grignard reactions?
Grignard reactions are commonly used in organic synthesis to create a wide range of organic compounds such as alcohols, aldehydes, ketones, and carboxylic acids. They are also used in the production of pharmaceuticals, fragrances, and plastics.
4. What are the benefits of using Grignard reactions?
Grignard reactions offer several benefits, including high selectivity and specificity, mild reaction conditions, and the ability to form complex organic molecules with ease. They are also versatile and can be used in various types of reactions, making them a valuable tool in organic chemistry.
5. Are there any limitations or risks associated with Grignard reactions?
While Grignard reactions have many advantages, there are also some limitations and risks to consider. These reactions are highly sensitive to moisture and oxygen, which can result in side reactions or incomplete reactions. They also require careful handling due to the reactivity of the Grignard reagents, which can be dangerous if not handled properly.
  • Chemistry
  • Chemistry
