jamesb-uk
- 69
- 0
Why is the air colder in the upper atmosphere?
bucher said:The air is colder in the upper atmosphere because of fewer air molecules (e.g. oxygen and nitrogen). These molecules all have their own energy in the forms of translational, rotational, and vibrational energy. With fewer air molecules, there is less energy that can be transferred to other molecules in the form of heat. With less heat, temperatures are colder.
SW VandeCarr said:I haven't heard that explanation before, but it could be one factor. The major factor is that the atmosphere is heated from the ground up. Solar radiation passes through the atmosphere without much direct heating of the atmosphere (especially colder dryer air). It heats the Earth's surface which in turn heats the air above it. Also descending air is heated due to compression at lower elevations according to Boyle's Law. Surfaces with high albedo such as snow or ice, reflect much of the solar radiation which in turn tends to sustain cold air masses over such surfaces.
Pinu7 said:Actually, a lost of that reflected heat is insulated in the lower troposphere.
Also, in the stratosphere, temperature actually increases with altitude.
