Why is the dust tail of a comet a tail?
  • Thread starter Thread starter edoarad
    Comet Dust
The dust tail of a comet is formed from physical debris released by the comet due to solar radiation and typically trails behind the comet's direction of travel. In contrast, the ion (gas) tail points directly away from the Sun, influenced by solar wind, which affects lighter gases more than heavier dust particles. The tails can appear to diverge in direction due to their differing responses to solar forces and the three-dimensional nature of their movement. Observers see the tails projected onto a two-dimensional sky, which can create the illusion of them pointing in opposite directions. Ultimately, the tails always orient away from the Sun, regardless of the comet's trajectory.
edoarad
is it also due to solar wind? if so why is it in a different direction than the gaz tail?
Astronomy news on Phys.org
The coma around the comet emits a large tail when solar wind and radiation pressure reach the comet; the tail is made up of dust and gas escaping the Nucleus of the comet.
The tail it self does not emit light but it reflects the light of the sun and start glowing because they are become ionized by the UV radiation.
The dust tail is physical debris that it ablated from the comet by solar radiation, and it tends to trail the direction of travel of the comet. The ion (gas) tail often points in a different direction because the gases are less massive than the dust/ice, etc and are carried away from the direction of the Sun by the solar wind. There are times when the dust and gas tails coincide, and there are times when they can appear to point in opposite directions from our vantage point. We seen the comets' tails as if they were projected on a 2-D sky, but keep in mind that apart from that X-Y alignment, there are also Z-components (toward or away from us) that we cannot observe.
Some people don't realize that the tail always points away from the Sun, regardelss of which way the comet is moving. Which means that, when the comet has rounded the sun and is on its way out of the system again, its tail is not a tail at all, it's a ... nose?
:P Indeed it is a nose. The ion tail always points directly outwards from the sun, no matter which way the comet is heading (aka towards the sun or away from the sun). While the dust tail (being heavier particulate material) tends to slope downwards and fall towards any local gravitational areas.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
