Is My Circuit Overloaded and Causing the Fuse to Blow?
  • Thread starter TSN79
  • Tags
    Fuse
In summary, the conversation discusses an overloaded circuit and a blown fuse. The person asks for advice on what to do, and is given information on what to check.
TSN79
424
I have a circuit in my house that sometimes blows its fuse. Now, electricity is not my field at all so I'm asking you guys. I know the fuse is 10 amps, I use perhaps 3,5 kW on this circuit, and we have 230 V over here. Don't know if that's enough info to make any form of judgement on whether or not I'm using to much stuff on this circuit, but I don't know what else to tell you...
Just a thought, is the load an electric motor? Motors have a very high inrush that can trip a breaker, even though the nominal current is well below the breaker rating. (Inrush is the current when the motor is started and before it gets up to speed.)
? What am I missing here? 3500/230=15Amps
As Russ pointed out, 230volts X 10 amps = 2300watts, well below both of your predicted loads.
Simply put, you have too much plugged in.
Ah, now I get the equation at least. Obviously I must have overestimated the load. Thx guys :)
10A sounds low for a 230V ring main. I would expect 15A or 30A
What have you got connected to the fuse, Lights or Wall sockets? this is important as it will affect how you track down the fault.
Do you know how many rings are in your house and how they are nominally connected?
Also what country are you in? as whilst I can track down faults I am much better with UK type wiring regs than US type ones, and what the Greeks do frightens me.
Easy peesy lemon squeezy. Overloaded circuit and fuse as already stated.
As Panda mentioned 10A is an odd rating. Have a look to check the cable size the circuit has been run on is substantial enough to take the load. Don't just bung in a higher fuse and forget about it. Unless of course you want to run the risk of an electrical fire (you don't) :wink:
FAQ: Is My Circuit Overloaded and Causing the Fuse to Blow?
1. Why is the fuse blowing?
The fuse is blowing because there is an excess of electrical current flowing through the circuit. This can be caused by a variety of reasons, such as overloaded appliances or faulty wiring.
2. How can I prevent the fuse from blowing?
To prevent the fuse from blowing, make sure to only use appliances that are within the recommended wattage for the circuit. In addition, regularly check for any faulty wiring and have it repaired immediately.
3. Does the location of the fuse affect its likelihood of blowing?
Yes, the location of the fuse can play a role in its likelihood of blowing. Fuses located in high-traffic areas or near heat sources may be more prone to blowing due to wear and tear.
4. Can a blown fuse be a sign of a larger electrical issue?
In some cases, a blown fuse can be a sign of a larger electrical issue. It is important to investigate the cause of the blown fuse and potentially consult a professional electrician to ensure there are no underlying problems.
5. How often should I replace my fuses?
Fuses should be replaced whenever they are blown. It is also recommended to regularly inspect fuses for signs of wear and tear and replace them every 5-10 years as a preventative measure.
