dainceptionman_02
- 23
- 6
i notice with physics, all the equations are a bunch of scrambled sentences or variables being multiplied together. why the multiplication for everything?
Can you give an example?dainceptionman_02 said:i notice with physics, all the equations are a bunch of scrambled sentences or variables being multiplied together. why the multiplication for everything?
##s = s_0 + v_0 t + \dfrac{1}{2} a t^2##dainceptionman_02 said:i notice with physics, all the equations are a bunch of scrambled sentences or variables being multiplied together. why the multiplication for everything?
Actually, there is a quite a bit of addition, much more than multiplication, but one tends not to think about it. For example, when one writes ##p=mv## keep in mind that ##mv=\sum_{i=1}^{N}m_i v_i## where ##N## is a humongous number for, say, a 1-kg ball that has ##N## atoms. We tend to forget that multiplication is a quick way to add things.topsquark said:Yes, there's a lot of multiplication, but there's also a lot of addition.
Because lots of things are proportional to lots of other things? And because units?dainceptionman_02 said:why the multiplication for everything
This is what. you spend your valuable time thinking about?dainceptionman_02 said:i notice with physics, all the equations are a bunch of scrambled sentences or variables being multiplied together. why the multiplication for everything?
More power to addition!A.T. said:We need equal representation of all operations. This multiplication supremacy has lasted long enough.
Seems ##\ln##ical.fresh_42 said:More power to addition!
\exp(x+y)
\exp(x) \cdot \exp(y)
Oops.
Take ##F=ma##. You know that the force needed to accelerate something increases for bigger masses. For a fixed mass you need a bigger force to get a bigger acceleration. Just from those two constraints, and no other reasoning, mathematically you must have ##F=ma## or ##F=m+a##. But the latter makes no sense - if you have zero force then you have ##m=-a## and an expectation that anything with mass accelerates when left alone (and if you put the vector signs in it makes even less sense). So ##F=ma##. You can apply similar reasoning to other things - in your Coulomb's law example you need your charges and your inverse square to multiply or you get silly answers.dainceptionman_02 said:i just always wondered why the theme of physics equations is always a bunch of products...
Dimension is the key! In its physical as well as in its mathematical sense. A dimension describes a physical quantity that is mathematically a vector space: we can add and stretch. Every other operation leaves the dimension. However, physics is the attempt to understand nature, and nature is full of different dimensions. If we consider how one changes if we change another, then we get a comparison: a proportion or exponentiation. Exponentiation is always related to growth, but proportions are all over the place, and the only possibility to compare two different dimensions! Voltage and current in the same lamp are related by power and resistance, a proportion. Weight and mass are related by the planet, a proportion. Proportions are actually the seed of science: the major subject in classical geometry. We cannot add current and voltage, but we can compare two relations of current times voltage.dainceptionman_02 said:for example, in electricity and magnetism, you have Coulomb's Law, various electric fields, potential difference, capacitance, resistivity, resistance, various magnetic forces and magnetic fields. all of them have tons of things being multiplied together. everything is multiplication! i know that unit wise, to get tesla, you have to do dimensional analysis with a bunch of variables, but i just always wondered why the theme of physics equations is always a bunch of products...
dainceptionman_02 said:for example, in electricity and magnetism, you have Coulomb's Law...
As a fan of algebras, I seriously have to disagree.DrClaude said:Multiplication is nothing but repeated addition, so it is addition all the way down!
Except when multiplication is non-commutative!DrClaude said:Multiplication is nothing but repeated addition, so it is addition all the way down!
Because, perhaps not surprisingly, multiplication and addition (and their inverses of division and subtraction) are the only operations that are unequivocal and absolute.dainceptionman_02 said:i notice with physics, all the equations are a bunch of scrambled sentences or variables being multiplied together. why the multiplication for everything?
That's obviously not true since the human mind has invented a lot more math than just these structures of algebra.diegogarcia said:I suppose that the human mind cannot conceive of anything beyond addition and the ratios that are expressed by multiplication.
Could you provide some examples?vanhees71 said:That's obviously not true since the human mind has invented a lot more math than just these structures of algebra.
There's Euclid's geometry to begin with.diegogarcia said:But my point is that addition and multiplication (and their inverses) are rock bottom. Everything other operation is merely an extension of them.
I do not know which emoticon to choose to show a reaction. My reaction I wish to pick is not an unfavorable one.Chestermiller said:This is what. you spend your valuable time thinking about?
Let's not drift backward from the context of MODERN physics and mathematics.PeroK said:There's Euclid's geometry to begin with.
Riemannian manifolds and differential geometry are the modern ideas that built ultimately on the basics of axiomatic mathematics developed by Euclid.diegogarcia said:Let's not drift backward from the context of MODERN physics and mathematics.
Your original point was the limitations of the human mind. You're now, sadly, engaged in defending your hasty and ill-conceived idea by desperate arguments. Is it really so difficult to admit you were wrong?diegogarcia said:Modern science is based on the analytical methods that began with Descarte and which introduced the idea of a number continuum.
The ancients, Greek or otherwise, had no such idea. Their theoretical mathematics was based entirely on angles. (A lot more can be said but this simple statement is quite accurate.)
The ancients derived trigonometry, for example, from the ratios of angles within triangles. This approach may still be taught in high-school classrooms but the modern approach is to derive the trig functions analytically using integrals.
I'm not much of a Euclidian-style geometer but I believe that most compass-and-ruler constructions, for example, have analytical algebraic equivalents. This was how "squaring the circle" was finally proved to be impossible.
So any allusion to Euclid is really highly inappropriate. We must stick with modern ideas.
