Why is Theta 2 Independent in Solving for Theta 3 in a 4-Bar Mechanism?
Theta 2 is considered independent in a 4-bar mechanism because its value can be chosen freely, allowing for the determination of dependent variables like Theta 3 and d. When Theta 2 is independent, it is possible to solve for other variables using a single equation from the system. Conversely, if Theta 2 is not independent, it complicates the solution process since there would be more unknowns than equations. The discussion clarifies that substituting expressions does not yield new information if the relationships are already established. Understanding the independence of variables is crucial for solving these types of mechanical problems effectively.
EastWindBreaks
it seems like because theta 2 is independent, therefor, you can solve theta 3 by just using one equation from the system of equation? on a previous problem where its a 4 bar mechanism( which it didn't specify that theta 2 is independent), you have to combine the system of equation into one single equation :
and then solve it from there using some substitutions. but for this problem, it didn't do that, is it because theta 2 is independent?
To answer the title question, ##\theta_2## is independent because you can change it at will. Once you choose a value for the independent variable ##\theta_2##, the dependent variables ##\theta_3## and ##d## acquire unique values. Did I answer your question? I am not familiar with what you refer to as the "previous problem."
Likes EastWindBreaks
thank you, I guess my question boils down to this:
if given a system of equations like this one below,
and if ##\theta_2## is not independent variable, then you can not simply solve ##\theta_2## by just using one of the equations, correct?
another question is that, for the example below where ##\theta_2## is independent variable:
can we solve both ##\theta_3## and d from just
EastWindBreaks said:
... and if ##\theta_2## is not independent variable, then you can not simply solve ##\theta_2## by just using one of the equations, correct?
Correct. You only have two equations which means that you cannot find ##\theta_2## in addition to ##\theta_3## and ##d## because that makes 3 unknowns.
I am guessing you were referring to this example:
##\theta_3## and d are unknown, one independent variable ( ##\theta_2##), yet d is solved using only 1 equation from the system of equations, containing 2 unknowns on the right side of the equation. so my question is if you can do that with d, then why can't ##\theta_3## = arccos( (a*cos##\theta_2## - d)/b) ?
... why can't ##\theta_3 = \arccos( (a*\cos\theta_2 - d)/b)## ?
Suppose you replaced ##d## on the right side with the expression you found, ##d=a*\cos \theta_2-b *\cos \theta_3##. If you do that, you get $$\theta_3 = \arccos( (a*\cos\theta_2 - a*\cos \theta_2+b *\cos \theta_3)/b)=\arccos(\cos \theta_3))=\theta_3.$$ So the answer to your question is, it can but you won't get anything new.
okay, I got it, thank you!
