Why mobile devices use same pins for charging and for pwr transferring
Mobile devices typically use three pins for battery connection, with two for power supply and one for safety. When charging, the device can draw power from the charger, allowing it to run and charge the battery simultaneously. Alternatively, some systems may operate off the battery while charging, which can lead to complications due to varying current demands. Power conditioning circuits are employed to manage the flow of electricity to different subsystems, ensuring stable operation. Understanding the distinction between charging and supplying power through the same pins is crucial for device functionality.
amit016
Mobile battery has generally 3 pins, 3rd for safety and 2 pins for supply. How can mobile devices get electricity during charging from same pins from where it is transferring power to mobile circuit?
Please help
I guess there are two ways that can work.
1. When charging, systems can get power from the charger. The charger both runs the system and the battery charging circuits. Then, when the charger power goes away, the system switches to the battery and run off it. It is fairly easy for the power circuits to switch without interrupting system operation. So, think of the mobile device as getting power from the charger if it is plugged in, or from the battery if the charger is not plugged in.
2. I've also worked on systems that charge the battery and run off it at the same time, and it causes no end of problems because the system draws a variable current, and the battery requires a precision current to charge correctly. But it is possible to work that way (I expect there are charger chips that do it all). You just need to compensate for the current being drawn by the system.
Not all devices will work the first way, but that is the easiest since you can start a system with a dead battery without waiting for it to get some charge.
All systems go through power conditioning circuits after the battery, generally a combination of switching and linear regulators to supply the various subsystems. Nothing generally runs directly off the battery.
Don't get confused about the two pins. When charging, power flows into the battery, and when supplying, power flows out. If a system and a charger were both connected to the same two pins (like #2 above), the system would essentially steal power from the charger while it was charging the battery. That is, the charger would power the system and the battery.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
