Do Paper Contracts When Burnt?
  • Thread starter Thread starter ajayraho
    Paper
When newspaper is burned, it contracts as it loses mass and volume due to the loss of water and the conversion of carbon compounds into gases. The heat drives off moisture, causing the paper to shrink, although the overall change in volume may be minimal depending on the paper's composition. The remaining ash can sometimes still display smaller, readable text if undisturbed. Additionally, the yellowing of paper over time is attributed to chemical reactions from bleaching agents used during production, which degrade and cause discoloration. This discussion highlights the physical and chemical changes that occur in paper when subjected to heat and time.
ajayraho
I have observed many times, that when a newspaper is burnt, its writings become smaller.
Do the paper really contract when burnt?
It's not clear what you are describing.
When I burn a newspaper, it turns to ash.
Hello Ajayraho,
I think your observation has credence.
The paper would have to get smaller and smaller as it burns.
For one thing all the water in the paper is driven off by the heat. The percentage change in volume night not be all that much, depending upon the makeup of the paper.
Next the carbon compounds are turned into gases that can burn with the oxygen in the air. So the paper itself is actually losing mass.
If you don't disturb the ash remaining, you can still sometimes read the now smaller print, at least where it hasn't curled up on itself.
Likes ajayraho, sophiecentaur and davenn
the paper itself actually loosing massmoreove moreover there were water before in the paper and vaporized after burnt the peper. However paper are not pure elements so the VDW between particle actually maintain constant but number of particle decrease so the paper contracts.
256bits said:
Hello Ajayraho,
A very satisfying answer..
So what's the reason behind the yellowing of papers, when kept for a long period of time?
Hi Ajayraho
actually, paper are not white from the origanls. it is yellow, we use some chemical bleacher to bleach the paper, however, the chemical will left ln the paper and during a long time, the chemical on the paper will reacts with paper which give a yellow colour on the paper
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
