Why Use Radians to Measure AC Sin/Cos Signals Instead of Seconds?
The discussion revolves around the choice of measuring alternating current (AC) sine and cosine signals in radians rather than seconds. Participants explore the implications of this choice in terms of mathematical representation, efficiency in calculations, and the relationship between time and angle in waveforms.
  • Some participants question why AC signals are measured in radians instead of seconds, suggesting a lack of understanding of the underlying concepts.
  • Others propose that radians provide a more efficient measurement unit for waves, facilitating calculations in engineering contexts.
  • One participant notes that radians relate to the cycles of a wave, emphasizing that 60 Hz corresponds to 60 cycles per second, which can be converted to radians.
  • There is a discussion about the definition of angles and how they relate to trigonometric functions, with some participants asserting that radians are not arbitrary and are essential for proper mathematical operations.
  • Some contributions highlight the complications that arise when using time in seconds, suggesting that it can lead to confusion without a clear reference to the waveform's period.
  • Participants mention the historical context of using complex numbers in electrical engineering and how this relates to the intuitive understanding of the relationship between time and angle.
  • Several comments reflect on the educational aspect of understanding radians, with some expressing frustration at the initial learning curve but acknowledging their necessity in the field.
Participants express a range of views on the use of radians versus seconds, with no clear consensus reached. While some argue for the efficiency and clarity of radians, others remain uncertain about their necessity and the implications of using time as a measurement.
Some participants note that using time as a reference can complicate discussions about AC signals, particularly when considering phase relationships and the need for conversions between units. The discussion also touches on the historical development of these concepts in electrical engineering.
This discussion may be of interest to students and professionals in electrical engineering, physics, and mathematics, particularly those seeking to understand the rationale behind measurement choices in AC signal analysis.
EngUOL
Could someone please explain why is chosen to measure ac sin/cos signals with radians instead of seconds? If ac waves is the behavior of a wave over time?
Any feedback would be appreciated. Thank you!
Sorry I know that is a stupid question to ask. But I got that concept missing. tHanks again
Why do we measure length in units like meters and time in units like seconds hmm...
No zoom I mean why is graphs in ac theory measured in radians instead of time. Like an amplitude against radians(wt) graph would it be amplitude against seconds? Or radians can be converted to seconds?
Zoky sorry
Argument must be naked number, or formally radian*.
Don't you think it will be unusual to try to calculate something like cos(1second)?
*Known reduction are degrees ( ° ), but we know it is per definition 2π = 360°
Thanks zoki. Ok so it's a matter of making things easier. The use of radians is just a more efficient measurement unit for waves. Is that right??
Well, if you know how to convert t=1second to radians than you can do it
Zoki i know that I am a completely dumb head lol but i don't understand the point of using radians instead of seconds.i have seen voltage over time graphs. but I've seen amplitude over radians graph. is radians another unit to measure time in this second case??
How are defined trig functions sin and cos ? What is their argument? How is defined an arc ?
Well, 60 hz is the same is 60 cycles per second.
Ok. Radians simply take that number then multiply it by 2π. 2π is one complete rotation of a circle, or of a cycle.
So, for example, the frequency for electricity is often 60 hz or 60 cycles per second as I mention above.
When you look at a sin wave of electricity, a single phase 120 volt system at 60 hz is represented by this:
170sin(377t)
170 is peak to peak...120 is RMS.
The figure 377 is obtained by multiplying 60*2π.
If you use this figure for example, 170sin(60t), your sin wave will be way off!
Most things in engineering and physics seem to work easier with the radians per second. But regardless, if a question is asked in the frequency domain, sometimes it's better just to leave it there. If it's asked in radians it may be easier to keep it there.
Say you are given a transfer function of 1/(jω+1), it makes sense just to leave it like that and plug in your radians per second.
You also need to be careful whether you are using radians or degrees. If you calculator is in degrees rather than radians in some cases, you will be wrong! Visa versa for the other way.
180 degrees is π radians. 360 degrees is 2π radians, 90 degrees is π/2 radians...etc.
There is more to it than I am saying, but that should start you on your way. This takes a while to figure out, let it come naturally over time.
very appreciated psparky. yea that kind of make sense. thanks a lot!
EnqUOL, how is defined an angle?
you tell me zoki
regards
Angle is a ratio of corresponding arc length and radius on given circle. This ratio is argument of trigonometric function. That's the whole philosophy.
When we first did Calculus at school we were told that differentiating sin(x) gave you cos(x) as long as x was in radians. If you accept that as a fact of life then the rest follows. That may strike one as being unsatisfactory but the simple statement helped us through until we had gone way past learning the calculus of simple trig functions.
Fact is that 'degrees' are a totally arbitrary way of chopping up a circle so it isn't surprising that using such an arbitrary measure can get you into difficulties and lumpy extra constants. The radian is not arbitrary; I always say that the inhabitants of the planet Zog could be using 128 of their degrees in a circle but they will still be using Radians when they do their proper maths.
Also - radians are a measure of "around the cycle" - and this is relative to typically one of the items you are discussing ( Phase A of a three phase system for example) - if you want to use "time" this becomes VERY arbitrary... as well when talking about AC we are typically talking about steady state. If you want to discuss a short circuit - then t=0 is very well understood ( and often used) - but that is a special case,
But for some system in the AC world we reference something as "0" - all other parameters are referenced back to that, like the Phase A. Look up a 3 phase phasor diagram... if you used a t=0 this diagram would look different every time - and be more complicated.
If you choose to use t, to specify a point on a waveform, then you must use a specific Unit (seconds or whatever), which will soon get you into a mess because you then need to refer it to the period of the waveform etc. etc.. Using Phase, in Radians (of course), the problem does not arise.
Sometimes, for practical reasons and in a particular context, Time is used, but it would be necessary to convert back to phase for any general conclusions to be gained from an experiment or measurement.
I know people will react against the apparent aggravation of getting to grips with Radians but one just has to grasp the nettle and get used to the little devils. You really can't do without them.
thanks a lot. best comment about my question so far. thanks to everyone thou!
It has become so widely accepted that we forget how we got here.
I think it was Steinmetz who first used complex numbers to represent cyclic voltages.
One's first instructor should take one through this diagram:
which paints in one's mind the relation between a wire loop rotating in a magnetic field and the voltage that results
and how natural is the relation between time and angle.
It becomes intuitive so soon that we old guys sometimes forget to introduce newcomers to it.
Now: sine function is a mathematical oddity because when you differentiate it its shape doesn't change
but it shows up all the time in physics, Mother Nature seems quite enamored of it...
And it shows up often in Mathematics (try a search on Euler). I suppose Mother Nature made mathematics too...
So it is the accepted "coin of the realm" in electrical engineering
Sharpen your skills with it early on.
As the kids say nowadays, "Just Do It".
old jim
Hehe, " Noli turbare circulos meos! "
old jim
If you were to come over here, your times would all be wrong though - even though your π and my π would be the same. (Also the engineers on planet zog)
Times all wrong ? hmmmm..
indeed i woke up last night realizing my wire loop analogy is likely off a quarter turn from the image i picked...
You guys over there don't have Whitworth phasors or something , do you ?
Ahhhh now think i see what you mean - the diagram i picked shows ωt pointing to a phasor labelled 30° not π/6 radians.
Yet ω is defined at top as radians/sec...
One must decide at start of every exercise what units he'll use, degrees or radians.
Rigor is the price of preciseness in understanding?
Thank heaven for Pi !old jim
  • · Replies 47 ·
  • · Replies 78 ·
19K
