Why would large quantities of dark matter not stick together ?
Dark matter does not compact like ordinary matter, as its particles interact very weakly with each other and pass through one another. This weak interaction raises questions about why dark matter and regular matter, such as dust belts, do not mix or stick together. The discussion suggests that rather than positing new substances like dark matter, it may be more effective to modify our understanding of gravity locally. Gravity's peculiarities lead to skepticism about its conventional understanding, especially since it operates as a geometric condition of spacetime rather than a form of radiated energy. As new instruments reveal previously unseen phenomena, the existence of dark matter continues to be confirmed.
mikenovice
Does dark matter form orbits around stars ? Why would dark matter and "regular" matter, say, a dust belt not mingle and stick together?
Just with black holes, with d.matter we are positing new objects with complex properties instead of simply admitting imperfection in gravity. Since it is difficult to show how gravity is mediated (as opposed to showing its effects, which are clear)...to me, Occham's razor is best applied by modifying gravity rules locally instead of inventing new substances.
Of course, it is inelegant to make exceptions to gravity, which works well. On the other hand, gravity is so strange as to be suspicious: something leaves a mass at lightspeed, collides with other objects: the effect of this collision is to suck the object against the direction of the impact, and it does not weaken from use, and penetrates any type of element ?
While gravity generally applies, it is so strange that one should be willing to think about exceptions.
Astronomy news on Phys.org
The problem is that Dark Matter is known to exist. Every time we develope some new isntrument with greater sensitivity, we see new things that we could not see before. Untill that moment, those things were Dark Matter.
...gravity is so strange as to be suspicious: something leaves a mass at lightspeed, collides with other objects: the effect of this collision is to suck the object against the direction of the impact, and it does not weaken from use, and penetrates any type of element...
Since the development of GR, this is not the way gravity has been understood to function. It is not a form of radiated energy, but a geometric condition of spacetime.
dark matter is not dark because scientists have seen dark matter and will see dark matter.
Dark matter, as conventionally defined, does not compact like ordinary matter. The particles simply pass through each other. They interact as weakly with one another as they do with ordinary matter.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
