Will a venturi work if the pressure behind it is
  • Context: Undergrad
  • Thread starter Thread starter forcedair
    Pressure Venturi Work
A venturi requires a significant pressure differential to function effectively. The necessary pressure differential is influenced by factors such as the desired flow velocity, the diameter and geometry of the venturi, and the properties of the fluid or gas being used. Without an adequate pressure differential, the venturi will not facilitate the intended flow. Specific calculations and parameters must be defined to determine the exact pressure differential needed for optimal performance.
  • Understanding of fluid dynamics principles
  • Knowledge of venturi design and geometry
  • Familiarity with pressure differential concepts
  • Experience with flow velocity calculations
  • Research the principles of fluid dynamics in relation to venturi effects
  • Study the design specifications for various venturi geometries
  • Learn how to calculate pressure differentials for different fluids
  • Explore flow velocity requirements for specific applications of venturi systems
Engineers, fluid mechanics students, and professionals involved in designing or analyzing systems that utilize venturi effects will benefit from this discussion.
forcedair
it was pointed out to me that a venturi won't function if the pressure differential before and after the venturi is minimal. how much pressure differential is required for it to work?
ty,
john
Pressure differential is responsible for the flow of fluid/gas through the venturi. Differential you need depends on flow velocity you need, diameter/geometry of venturi, and properties of the fluid/gas involved. You would have to be far more specific to get a useful answer.
  • · Replies 160 ·
10K
  • · Replies 16 ·
