Will i need amplifier in this case?
  • Thread starter Thread starter samaaa
    Amplifier
5 replies · 2K views
samaaa
Hi:
i have ADC(analog to digital) has a resolution 12 bits
and the input range is from +50mV to -50mV,
this men the precision is about 24uV
i want to use this ADC for a signal has Vp.p from 0.7mV to 1mV
so
can i use this ADC directly?or i must use amplifier ??
You could just use the ADC but the problem is you only have 12 readings in that voltage range. If you need more resolution than that you need an amplifier.
no, i have 29 readings (from 700uV/24uV) .
how can i know what is the resolution i must use??
is there any equation to determine the resolution?
The resolution you need depends on what you are trying to measure, in some cases two values might be enough!
However, remember that the input noise of your ADC is also an issue, so in real life you will always need an amplifier.
Just get/build an amplifer with a gain of 50.
If you have a signal that you know ranges from 0.7mv to 1mv I would think that when measuring it your interest would be in the 300uV difference between the two.
you don't understand me, the signal has Vp.p=700uV or 1 Vp.p(ECG signal)
the range may be from - 500uV to 500uV
