Will we live in and wear graphene in the near future?
Graphene is poised to significantly impact various industries, potentially transforming products like cars, clothing, and electronics. While it is a promising candidate as a post-silicon material for electronics, its widespread application remains in the research phase. If graphene proves successful in this role, it could become as ubiquitous as silicon is today. The ongoing evolution of technology will likely continue to enhance connectivity and data-driven solutions, regardless of the materials used. The future integration of graphene into everyday life is plausible, but its current status is still largely speculative.
Dragul
From what I'm hearing, graphene will change the way we live, work and play. Everything from cars and clothing to workplaces and weaponry will incorporate the stuff. Is this true, the hype of stock promoters or something in between?
Which aspects of life will be the most affected by the use of graphene?
Are there other elements that could be formed in atom-thick honeycombs or other configurations that give us additional properties?
No.
Likes Tazerfish, russ_watters and Bystander
Graphene is a potential post silicon material for electronics. This is a very active area of research. If it ends up winning the post silicon design then yes it will be incorporated in a large number of products. It will be "in everything" in exactly the same way as silicon electronics are "in everything" now. The hyperbole of the OP will be true-ish of whatever the next generation of electronics ends up being.
It is true-ish of our current generation of electronics. We live in an increasingly connected and data driven world. I would expect that to continue to increase regardless of the materials used.
BoB
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
