rcgldr
Homework Helper
- 8,923
- 675
A propeller uses an AOA versus prop disk that decreases as radius increases, normally set so that the propeller pitch (the effective advanced distance per revolution) is the same at all radius (except for the hub).A.T. said:variable propeller pitch
It might be easier to figure the math out if you knew the pitch numbers for the BB propeller. There's a physical pitch based on geometry, and the effective pitch based on air flow. Some props have the pitch measured in a static flow (no headwind) situation, but there is an induced headwind in the vicinity of the prop. Some simplified static thrust calculators ignore the geometrical pitch of a prop. If there was a headwind speed that corresponded to the geometric pitch times revolutions per unit of time, then the propeller would not increase the air speed except for the twisting (torque) of the air flow.
In the meantime, I've run into a math problem trying to determine a limit. For an ideal (no losses) sailcraft that diverts apparent wind directly aft of the sailcraft (diverting it to become an apparent headwind), the limit of the flow aft of the sailcraft wrt ground approaches wind speed x cos(θ) as the sailcraft speed approaches infinity.
Here are the formulas:
θ = sailcraft heading wrt wind. θ = zero means directly downwind.
v = sailcraft speed
w = true wind speed
aw = apparent wind speed (wrt sailcraft)
da = diverted apparent wind (the wind flow off the aft end of the ideal sail) wrt sailcraft
dw = diverted apparent wind wrt ground
ac = apparent cross wind = w sin(θ)
ah = apparent head wind = v - w cos(θ)
aw = sqrt(ac2 + ah2)
aw = sqrt((w sin(θ))2 + (v - w cos(θ))2)
aw = sqrt( w2 + v2 - 2 w v cos(θ) )
after the idealized sail diverts the apparent wind, it is in the same direction as the sailcraft, so da has the same magnitude as aw, just a different direction.
da = sqrt( w2 + v2 - 2 w v cos(θ) )
The speed of the diverted wind relative to ground is
dw = v - da = v - sqrt( w2 + v2 - 2 w v cos(θ) )
using a spreadsheet to test the formula, it turns out that
limit v -> ∞ of dw = w cos(θ)
However I'm not able to directly solve this limit.
Continuing, the downwind component of dw = dw cos(θ), so
limit v -> ∞ for dw cos(θ) = w cos2(θ)
The true wind is slowed down by w - dw cos(θ), so
limit v -> ∞ for w - dw cos(θ) = w - w cos2(θ) = w sin2(θ)
This limit is approached from above, with slightly higher numbers at lower speeds. The point of this is that the true wind is slowed by at least wind speed x sin2(θ) regardless of the idealized sailcraft speed. This is getting back to the point that for an ideal sailcraft, there is some finite power input but zero power consumption, so there's no mathematical limit to the sailcrafts speed.
