Ultrasonic2 said:
ok guys I am an old guy that is useless at maths so i'd like your help.
I have searched the net and this forum and i have found some formula but I am to thick to work it out even with an equation.
https://www.physicsforums.com/showthread.php?t=117105
This isn't home work as i haven't been to school for a long time now .. probably if i was at school i could have understood peoples replies
Basically what i want to know is for a 100mph wind what is that in psi ?
i obviously want to be able to change the mph and see the result in psi is but i need REAL basic maths.
From what I've read so far it's important to know I am at sea level
Please help.
Thanks for your help in advance Michael D
Well not sure if the OP is still interested in his quarries, yet I will assume he is and speak directly to his musings.
So, while his question is an important aspect of wind shear, and loading as applied to standing structures--ie. Buildings, Windmills, ect sic--I believe, and so assert and retort; that a direct and constant that will convert wind velocity to applied force, can not be made without considering the 'area', in square proportions, of the structure under analysis. With that said, mind you; the general principles that must come under study; are those set forward by Sir Newton, Messrs Pascal, Bernoulli in their discourses of physical minutia.
So Sir Newton would of course consider the kinetic forces of the moving wind, and of course would need to know the general atmospheric pressure, at the point(s) in question, ie, sea level, versus, at some specified elevation, he would must also be of interest in the moisture content of the wind mass moving at the stated rate; along with any other dejecta materials--ie, sand, dirt, objects de art, Dorthy and Toto, to name a few.
So after Sir Newton felt he had stated his principles sufficiently he would sit down in triumph on his laurels, and allow Mr Pascal to step up the the podium. Cough several times and retort;
'A change in pressure at any point in an enclosed fluid at rest is transmitted undiminished to all points in the fluid'
and then, after glaring at all the bright minds before him, gesture to Mr Bernoulli, and return to his sedan.
Now of course Mr Bernoulli having had the problem so well quoted would glance up and to the left, cock his left eyebrow and utter;
"that for an inviscid flow, an increase in the speed of the fluid occurs simultaneously with a decrease in pressure or a decrease in the fluid's potential energy. "
So now with the issues so dramatically made know, an analysis of the question at hand can be sought First; we have the mass of the atmospheric fluid; yes a fluid, if a gas isn't fluid then I don't wish to consider living any longer; so, the mass of the gaseous medium, considered at what elevation it is at, and the moisture content, along with any other stray objects picked up in the course of it's travels; this force is Kinetic; yet described in terms of itself only, is potential. If this mass is moving at the rate of 100mph, for example we will say 44.704 m/s AND if, it strikes, say a 150 foot square billboard, say 1,614.60 m sq As this force (sic) strikes square direct, on the structure, it will shear 90 degrees, which will then radiate equally in all direction on the surface of the standing structure.
This force acting on this surface are which creates the pressure differential, between the wind face; and the area behind this face. The pressure behind the object does not change; the change in vector forces, which create a 'LOWERED' pressure on the wind side area of the structure that will at first be pulled in the inverse direction of the wind (the billboard). The window is not being 'blown' in, it's being 'sucked out' The higher force, 'static air pressure; as compared to the lower pressure on the wind loading surface, caused by the vector change in conjunction with the change in velocity in the new direction, cause a lowered state of pressure, as noted by Pascal, and Bournelli.
Thus, the wind doth truly suck.
Respectfully submitted for discussion
jeffrey
