Wind velocity and aircraft (answer check)
The discussion revolves around calculating wind velocity for a pilot's flight. The effective southward velocity is determined to be 900 km/h, while the actual velocity of the plane is calculated using trigonometric functions based on its speed and heading. By subtracting the actual velocity from the effective velocity, the wind velocity is derived. The final calculation yields a wind velocity of approximately 267 km/h. This confirms the accuracy of the solution presented.
negation
You’re a pilot beginning a 1500-km flight. Your plane’s speed is 1000 km/h, and air traffic control says you’ll have to head 15° west of south to maintain a southward course. If the flight takes 100 min, what’s the wind velocity?
veffective south = vactual + vwind
veffective south = 1500kmh^-1 / 1.667hr = ( 0, -900kmh^-1 )
vactual = (1000kmh^-1 cos 255, 1000kmh^-1 sin 255) = (-258.82kmh^-1 , -965.93kmh^-1)
vwind = veffective south - vactual
therefore
(0, -900kmh^-1 ) - (-258,82kmh^-1, -965.93kmh^-1)
= (258.82kmh^-1 , 65.93kmh^-1)
= |vwind| = SQRT [ (258.82kmh^-1)^2 + (65.93kmh^-1) ^2]
I think you should punch the final numbers in your calculator, take the square root, and come up with one number for the answer.
The answer is 267kmh^-1
I confirm that answer.
