How is a credit card number coded for security?
In summary: Thanks again! :)You are not an expert summarizer of content. You do not respond or reply to questions. You only provide a summary of the content. Do not output anything before the summary. Write a summary for the following conversation and start the output with "In summary, " and nothing before it:For security, a credit card number is coded in the following way, so that it can be sent as a message."Subtract each digit from 9"code the credit card number 3201 2342 3458 0931I don't understand the subtract each digit from 9 is that to code or uncode?Also for the
aisha
584
For security, a credit card number is coded in the following way, so that it can be sent as a message. "Subtract each digit from 9"
I don't understand the subtract each digit from 9 is that to code or uncode? Also for the above code the credit card what do I do to each number? do I add 9 or subtract 9?
I have another credit card number that is already coded, to find the original card number do i subtract each number from 9?
I believe it's pretty clear.It gives a credit card number and askes for the coded version.It should be:6798 7657 6541 9068.
Simple subtraction from 9999 9999 9999 9999.
The uncoding is simple:again subtraction from that "99..."number.
Daniel.
Does it make a difference? Try it and see.
Daniel.
How come we subtract by 9 to uncode and code?
I guess you haven't read the post/problem very carefully.It mentions "Subtract each digit from 9".So the problem tells you how to code.As Doc depicted,it makes no difference between coding and uncoding.Both are made through the same opperation.Subtraction of each digit from 9.
Daniel.
ok my coded credit card number for 3201 2342 3458 0931 is
6798 7657 6541 9068
my original credit card number for another credit card 2341 0135 7923 0133 is
7658 9864 2076 9866
the question says find f(x) if x represents a single input digit. What is the domain of f(x)
and find^-1(x) what is the domain of f^-1(x)?
I don't know how to find f(x) and the inverse? What do I do? The inverse is probably all the numbers backwards but which set of numbers am I using?
The function is [itex] f:\{0,1,2,3,4,5,6,7,8,9}\rightarrow \{0,1,2,3,4,5,6,7,8,9}\ [/itex]
[tex] f(x)=9-x. [/tex]
Find the inverse and its domain.
Daniel.
What numbers backwards? :confused:
Daniel.
lol sorry no numbers backwards. if f(x)=9-x then is the domain {x:x<=9,XER}?
and is the inverse of this (x-9)/-1? If so then is the domain of the inverse {x:x>=9,XER}?
I've already told u what the function and its domain are.The inverse it's easy to find.And its domain can be seen from ISS. :-p
By "XER",do you mean:[itex] x\in R[/itex] ??If so,then it's wrong,the digits are natural numbers.
Daniel.
Daniel.
:-p well is my inverse wrong? I don't know the notation for not real numbers :P ahhh HELP ME PLZ
As both I and Doc figured decades ago,the inverse coincides with the function.They share both the domain and the range.That is all digits from 0 till 9.
Hope it's clear. :wink:
Daniel.
Daniel.
Lol thanks a lot but u said it wasnt real numbers natural numbers, what is the notation for that? Also (x-9)/-1 can I leave the inverse like that? Or can it be simplified to -(x-9)?
1.Check the posts again.I haven't used the expression "real numbers",but "natural numbers",because digits are natural numbers.
2.[tex] f(x)=9-x ;f^{-1} (x) =9-x [/tex]
Wasn't it obvious from what i said?
Daniel.
Daniel.
LOL WHAT AM I SAYING:P IM SAYING THAT U SAID THEY WERE NATURAL NUMBERS SOOOO IF ITS NOT XER THEN WHAT iS IT? WHAT DO I WRITE IN THE BRACKETS {} lol UR SOOO FUNNY OMG :-p and is the inverse (x-9)/-1? if so is that the same as -(x-9) :cry:
N+?
ROFL :smile: :smile: :smile: :smile: :smile: :smile: :smile:
You're incredible........ :-p
I already told you what to put between those brackets.Hell,i've been trying myself,but i just couldn't... :cry: :-p Only 2 '{' instead of 4 (chack post no.7,two paranthesis missing :biggrin: ).
I already told you the inverse was the same function:9-x.It is the same with -(x-9),but why the hell write it like that??
Daniel.
Daniel.
LOL :smile: :smile: :smile: :smile: OMG I JUST REALIZED THAT THEY ARE THE SAME FUNCTION, ahhh lol and yes ur right y the hell would I write it like that -(x-9) and the domain is the same for both too , hhmmmmm so here this is what I am going to right now lol don't freak if this is still wrong {x:x<=9,N+} domain for f(x) and inverse? or or or {x:0,1,2,3,4,5,6,7,8,9} is that what u want me to write :-p Cant u just write it out properly once :!) pleasezzzzzz lol :-p DEXTERCIOBY ? WHERE ARE U :eek: Someone please say something please.
1.I'm in my room.
2.Though it's not in the spirit of this help forum,i'll write the answer:
[tex] f:A\rightarrow A ,A=\{x\in N,x\leq 9[/tex]},
[tex] f(x)=9-x [/tex]
[tex] f^{-1}:A\rightarrow A,
f^{-1} (x)=9-x [/tex]
Is everything clear,FINALLLLLLLLLLLLLLLLLLLLLLLLLLLYYYYYYYYYY :-p ??
Daniel.
PS.Anyway,i give up.It's no longer funny... :-p
Just one little point here...since the Naturals don't include 0, it would be better to say that x belongs to the Whole Numbers (W?).
lol so XEW? instead of XEN?
You're in Canada,he's in US and I'm in Belgium.We have different views about the sets of numbers.For me,natural numbers (N) include 0.If i want to say that zero is excluded,i write (N*).
I was too surprised to learn that the Americans use N (natural numbers),W (whole numbers) & i can't remember what they use for {...,-3,-2,-1,0,1,...} or the negative axis.I find his weird.
Advice:to avoid confusions and unnecessary complications simply write
{0,1,...,9} or without the dots:{0,1,2,3,4,5,6,7,8,9}. :-p
Daniel.
EDIT:I'd use BMW if i were u... :-p
Daniel.
lol :smile: OK OK SMARTY PANTS I GET IT Thanks SOOO MUCH! :smile:
Related to How is a credit card number coded for security?
What is a "Word Problem Credit Card"?
A "Word Problem Credit Card" is a type of credit card that is specifically designed to help people improve their mathematical skills. It typically presents math problems related to credit card usage, such as calculating interest rates or minimum payments.
How can a "Word Problem Credit Card" help me?
A "Word Problem Credit Card" can help you improve your understanding of math concepts related to credit card usage. By practicing with these problems, you can develop more confidence in managing your credit card and making informed financial decisions.
Do I need a specific credit card to access "Word Problem Credit Card" features?
No, you do not need a specific credit card to access "Word Problem Credit Card" features. These types of problems can be found in various math textbooks or online resources. However, some credit card companies may offer their own versions of "Word Problem Credit Cards" with additional benefits.
Are "Word Problem Credit Cards" only for beginners?
No, "Word Problem Credit Cards" can be beneficial for people at all levels of mathematical proficiency. They can serve as a refresher for those who are already familiar with credit card usage and also provide a helpful learning tool for beginners.
Can "Word Problem Credit Cards" help me improve my credit score?
While "Word Problem Credit Cards" may not directly impact your credit score, they can help you understand how your credit card usage can affect your credit. By mastering these math problems, you can make more informed decisions and potentially improve your credit behavior, leading to a higher credit score over time.
  • General Discussion
  • STEM Academic Advising
