Work and energy for a lowered block
The problem involves a block being lowered vertically with a specific mass and acceleration, requiring calculations of work done by different forces, kinetic energy, and speed after falling a certain distance.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the forces acting on the block, including tension and weight, and question the relationship between these forces and the net force. There are attempts to calculate work done and tension using free body diagrams.
Some participants have provided guidance on drawing free body diagrams and clarifying the directions of forces. There is ongoing exploration of the correct equations and calculations, with no explicit consensus reached yet.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is uncertainty regarding the correct application of forces and calculations.
Kpgabriel
A cord is used to vertically lower an initially stationary block of mass M = 35 kg at a constant downward acceleration of g/5. When the block has fallen a distance d = 6.5 m, find the work done by the cord's force on the block.
Find the work done by the weight of the block.
Find the kinetic energy of the block.
Find the speed of the block.
W = F*d
F = m*a
So I tried finding the first part of the question where I multiplied the mass, 35 kg, and multiplied it by the acceleration, 9.80/5= 1.96, to get F= 198N and then I multiplied the force by the distance to get the work and got 445.9 J but it is wrong.
Note: Thread title changed to describe the question subject matter.
Have you drawn a the free body diagram for the situation? What forces are operating on the block? Is the force due to the cord the same as the net force on the block?
No, I do not think it is. So I drew out the free body diagram and I got that the Tension force of the cord, T - mg = ma. So T = ma + mg
For this I got 411.5 N
To solve for work I multiplied it by 6.5m and got 2675.4J which is wrong. I am not sure what I am doing.
Your equation describes a mass accelerating upwards with acceleration a. Your free body diagram should help you to sort out the directions of the vectors and the signs of the terms in your equation.
So the Tension force would be equal to T= M*g - M*a and that is equal to 274.4N
That looks reasonable. Be sure to keep track of the directions of the forces acting versus the direction of the motion of the block.
  • · Replies 47 ·
