Work definition in thermodynamics
This discussion focuses on the calculation of work in thermodynamics, specifically through three key equations: W = pΔV for constant pressure processes, W = nRTln(V2/V1) for isothermal processes, and a corrected interpretation of CvΔT for constant volume processes. The first law of thermodynamics, Q = ΔU + W, serves as the foundational principle connecting these equations. Clarifications were made regarding the use of these equations in different thermodynamic processes, particularly in adiabatic expansions where work can be derived solely from temperature changes.
  • Understanding of the first law of thermodynamics (Q = ΔU + W)
  • Familiarity with ideal gas laws and properties
  • Knowledge of thermodynamic processes: isothermal, adiabatic, and constant volume
  • Basic calculus for integrating pressure-volume work
  • Study the derivation of the first law of thermodynamics in various processes
  • Learn about the implications of adiabatic processes on internal energy and work
  • Explore the concept of heat exchange in constant volume processes
  • Investigate real gas behavior and deviations from ideal gas laws
Students and professionals in physics and engineering, particularly those specializing in thermodynamics, mechanical engineering, and chemical engineering, will benefit from this discussion.
ricard.py
Hello,
I have been self-learning Thermodynamics and I am having a bit of trouble with calculating the work in different circumstances.
Along the lectures we have come up with three different equations for work
1) W = pΔV
2) W = nRTln(V2/V1)
3) W = CvΔT
So my questions are:
1) which ones must be used in which type of thermodynamic process? For instance, the third is used in adiabatic processes, but the second
2) If using the second formula in a reaction that changes the temperature along it, we have to take as T the initial temperature, the last temperature, the difference..?
2) Accoding to the first equation, if V is constant, then W=0. However, according to the last formula the work only depends on T and we can get work done without modifying the volume. Why this is not contradictory?
Thanks!
Science news on Phys.org
Formula 1) should be used for processes at constant pressure. Formula 2) is used for processes at constant temperature. Formula 3) is wrong. It should read Q = CvΔT, where Q is the heat exchanged in a constant volume process.
Ok thanks!
Concerning the third equation I forgot to say that it is in a context of a diabatic expansion (q=0). Therefore, ΔU=CvΔT=W.
Then in a diabatic expansion, we can have work only dependent on the T and not on the V. How does this not contradict the "classical" definition of W=pΔV?
ricard.py said:
Hello,
1) W = pΔV
2) W = nRTln(V2/V1)
3) W = CvΔT
There is no sense in memorizing formulae. These all derive from the first law: Q = ΔU + W (where Q is the heat flow into the system, ΔU is the change in internal energy of the system and W is the work done BY the system that undergoes a change in thermodynamic states).
The first law applies between any two thermodynamic equilibrium states regardless of the process followed in moving between those two states. However it can be rather difficult to calculate these quantities if the thermodynamic properties are undefined during the process.
In the case of an expansion at constant pressure - where, for example, the work is done against constant atmospheric pressure - the work done BY the system is just W = ∫PdV = P∫V = PΔV. So Q = nCPΔT = ΔU + PΔV
In the case of an adiabatic expansion, Q = 0 so ΔU + W = 0 which means W = -ΔU. If you are dealing with an ideal gas where ΔU = nCVΔT then W = -nCVΔT
In the case of an isothermal compression of an ideal gas where P = nRT/V, the work done in compressing the gas ( -W = work done ON the system) is:
-W = - ∫PdV = - ∫(nRT/V)dV = -nRT∫dV/V = nRTln(V1/V2)
AM
duplicate post
  • · Replies 37 ·
  • · Replies 135 ·
  • · Replies 60 ·
10K
