How Do You Calculate Work Done on an Incline with Ambiguous Angle References?
To calculate work done on an incline with ambiguous angle references, it's crucial to clarify the angles involved. The force of 80N is applied at 170 degrees from the x-axis, while the object moves 2.2m at an unspecified angle of 10 degrees. The net force can be determined by using the horizontal component of the applied force, calculated as 80N times the cosine of 170 degrees, multiplied by the distance. The ambiguity arises in interpreting the 10 degrees, which should likely be referenced from the same axis as the first angle. Understanding the reference for both angles is essential for accurate calculations.
Xet
object with force of 80N at 170 degrees from x-axis...
moved of a distance of 2.2m at an angle of 10 degrees
problem does not state exactly 10 degrees in respect to what...
net force is equal to force applied in the horizontal direction (force times cosine of angle) times the distance...
After using all my tries on this problem (WebAssign), I realized it's not 10 degrees with the applied force because it would be just simply 80cos(170)2.2...
If I were to calculate the 10 degrees factor...how would I do it? I thought about trying 160 degrees of the applied force...but there's no way to find out the right answer because I used all my attempts...
There's a few more I'm bound to have troubles with so I'll just continue posting...
Sounds good to me.
Since the first angle (170) was with respect to the x-axis, one would assume that's the reference for the second angle as well.
