The discussion revolves around the concept of work done by a gas under constant pressure, specifically addressing whether the pressure in the work equation refers to the gas pressure or the external pressure. Participants explore the implications of different scenarios, such as free expansion and dynamic work, and how these affect the application of the work formula.
- Exploratory
- Technical explanation
- Debate/contested
- One participant questions whether the pressure in the work equation refers to the gas pressure or the external pressure, noting confusion based on differing opinions heard.
- Another participant explains the derivation of the work equation, asserting that the pressure used should be the gas pressure when considering work done by the gas.
- It is suggested that for work done on the surroundings, the external pressure should be used, although these pressures can sometimes be equal.
- A participant introduces the concept of free expansion, stating that in such a case, the work done is zero, and thus the internal gas pressure should not be used to determine work done.
- Concerns are raised about non-quasistatic processes, where using the integral of pressure to determine work may not yield accurate results due to dynamic work considerations.
- Further questions are posed regarding the applicability of the work equation in special cases like free expansion and the relationship between internal pressure, external pressure, and kinetic energy of a piston in a dynamic scenario.
Participants express differing views on the appropriate pressure to use in the work equation, with some advocating for gas pressure and others for external pressure. The discussion remains unresolved regarding the implications of non-quasistatic processes and the conditions under which each pressure should be applied.
Participants highlight limitations in applying the work equation under certain conditions, such as free expansion and dynamic work scenarios, indicating that assumptions about pressure may not hold in all cases.
